Nismo Short Shifter
Old Jan 7, 2008 | 07:29 PM
eK9aT10pSi's Avatar
Nismo Short Shifter
hey guys, the max [02+] with 6 speed, what size is your bell housing for the shifter under the hood? is it 67mm or 55mm ? i ask this b/c i think its the same for the 04 6th gen. the 05+ changed to the 55mm. TIA
Old Jan 7, 2008 | 07:39 PM
DasYears
02-03=6th gen 6spd
Old Jan 7, 2008 | 07:45 PM
SoonerFan's Avatar
Cletus
nismo shifter...overpriced rice
Old Jan 7, 2008 | 07:50 PM
eK9aT10pSi's Avatar
thx for the replies. i am looking for the bell housing size. thanks!
Old Jan 7, 2008 | 07:51 PM
eK9aT10pSi's Avatar
i didnt mean the shifter, i meant the short shift adapter, sorry for the confusion.
Old Jan 7, 2008 | 07:55 PM
SoonerFan's Avatar
Cletus
sorry...just went by the title - Nismo Short Shifter
Old Jan 7, 2008 | 08:11 PM
DasYears
i doubt anyone knows. if youre looking to buy one, just do the free STS mod
Old Jan 7, 2008 | 09:52 PM
eK9aT10pSi's Avatar
^^^^^^^^^ link ?
eK9aT10pSi's Avatar
my bad, lol; after i did the post, i didnt realize i cant change the title.
Old Jan 8, 2008 | 05:05 AM
miksen's Avatar
FU, FU, FU, You're Cool..
Do you have this link for this write up? it will save me 150
Old Jan 8, 2008 | 08:30 AM
'02_EMILBUS's Avatar
hows the cattman STS Sooner???? Worth buying rather than doing the "free STS"??
Old Jan 8, 2008 | 09:07 AM
SoonerFan's Avatar
Cletus
yes
Old Jan 8, 2008 | 02:41 PM
DasYears
yes
do you have a back to back comparison to support this outlandish claim?
Old Jan 8, 2008 | 05:53 PM
SoonerFan's Avatar
Cletus
i have driver cars with both.
what proof do you have to discount my statement?
who do people always questions members that have proven themselves
Old Jan 8, 2008 | 05:56 PM
MintVQ35's Avatar
There used to be a guy that made his own STS for the 6spd, he sold them for $65 shipped on the nycmaxima forum, not sure if he still makes them but you may want to check it out. I have this one and it works great, I was going to do the free STS until I saw this guy was clearing his current stock out...If he no longer makes it I would also recommend doing the free STS over spending $150.
Old Jan 8, 2008 | 08:30 PM
DasYears
the free sts is innocent until proven guilty (not as good/as good as a purchased unit). the free sts gives you the same result as purchased unit, but gives you the opportunity to choose the throw lengths and the shifter position
what have you done to prove yourself?
Old Jan 9, 2008 | 04:24 AM
vball_max's Avatar
Old Jan 9, 2008 | 11:16 AM
02Maximan's Avatar
Here ya go bro... http://forums.maxima.org/showthread....light=free+sts
Buy the ES shifter bushings from cattman to go along with this mod and you'll definitely be pleased.
BTW... don't use a power drill to tap the drilled hole. I broke the tap off in there and had to find a special extractor to remove it. If you turn it by hand you won't be able to break the tap.
Old Jan 9, 2008 | 02:19 PM
DasYears
yeah...using a power drill to tap a hole of normal size is a nono
Old Jan 9, 2008 | 04:52 PM
SoonerFan's Avatar
Cletus
so i have proof...ive driven both. and you have nothing.
quick question? after the free STS...where is the shift **** compared to stock?
that doesnt even deserve a response.
Old Jan 9, 2008 | 05:51 PM
IWNTMORHP!!'s Avatar
CAN YOU PUT IT ON THE WALL?
the stock location on the 04-06 manual tranny provides a shorter throw than the 02-03. I swapped the tranny in my 02 and I couldn't use the TWM STS because the selector was different on the new tranny and the TWM wouldn't fit without modding by grinding part of it down. If you are able to swap that out for the 04 version, the shift is only slightly longer...maybe 2cm than the TWM STS and the stick position is near stock. hope that helps.
Old Jan 9, 2008 | 08:51 PM
DasYears
i got in the car and felt out several locations (forward of stock, backward of stock) and picked out what i liked best. it mostly in the middle, but i thought stock was a little too far forward so i placed it further back than stock
typical of your posts
Old Jan 9, 2008 | 09:40 PM
02Maximan's Avatar
thats the good thing about this mod (other than it being free, obviously) In neutral the **** sits right right where it did before. If I wanted it to sit farther back I could have drilled for it to be there.
BTW sooner I could about swear in a previous thread you said that you would have just went with free sts if you hadn't have come across a cheap Watkins STS. Maybe it was Puppet that said that...
Old Jan 10, 2008 | 03:13 AM
DasYears
hes been known to flip flop like john kerry
Old Mar 3, 2008 | 05:56 PM
axxtion's Avatar
I've got Axxtion STS's in stock. Both the 55mm and the 67mm.
click on pic to see larger view
55mm shown
axxtion@hotmail.com
Old Mar 3, 2008 | 06:02 PM
SoonerFan's Avatar
Cletus
just noticed this...i may be "mean" but if there is one i dont do - its flip flop.
jmlee44
Oct 2, 2022 02:13 PM
Fbana41
Aug 29, 2016 12:18 PM
05RLS2
Apr 14, 2016 11:49 AM
atriuum
Sep 28, 2015 01:19 PM
