Strange Noise with Steering
Old Jan 9, 2008 | 06:17 PM
wyche89's Avatar
My car (2003 6MT) is making a strange whirring noise when the steering wheel is turned all the way, and moving forward (haven't tried backward yet). The noise goes away as the wheel turns back to a normal straight position. Does anybody know what this might be?
Old Jan 9, 2008 | 06:25 PM
SoonerFan's Avatar
Cletus
bearing.....
Old Jan 9, 2008 | 06:36 PM
n3985's Avatar
大陆弟弟
steering bump stops.....
Old Jan 9, 2008 | 09:15 PM
wyche89's Avatar
Originally Posted by soonerfan
bearing.....
ok.. edit.. i tested it tonight, and it does do it while backing up as well.. 2 more questions:
1. there is one bearing for each of the front wheels right?
2. can there be any long term effects if i dont change them?
Old Jan 9, 2008 | 09:17 PM
wyche89's Avatar
i dont understand what you're trying to say...
Old Jan 9, 2008 | 09:21 PM
kaneda_77's Avatar
Yes, bearing on each side.
Yes, you'll want to change them, i've had bearings fuse to my axle after they seized and it is a serious PITA to deal with that. it could cause a serious jerk when you're driving and cause an accident.
I don't know if it's your bearings though, do you feel the hum in your steering wheel or on the floor more? If you are feeling it more in the steering wheel it might be your steering pump or something like whatever n3985 said.
Old Jan 9, 2008 | 09:23 PM
wyche89's Avatar
i'm not really FEELING it... i'm moreso just hearing it when i make a sharp turn and/or u-turn.. i'll check tomorrow if i feel it for sure though.. although sometimes i do feel a slight vibration in the clutch pedal when it's depressed.. i don't know if the 2 issues are connected or not
Old Jan 9, 2008 | 10:28 PM
kaneda_77's Avatar
If worse comes to worse, take it to midas/meineke and have them do their brake and maintenance inspection for you. Just tell them you hear the sound and let them diagnose it for you. They will probly try to get you to replace the brakes even though they are good... lol. They do them for free(at least they used to).
Old Jan 10, 2008 | 08:16 AM
maxximaa's Avatar
lol...
Old Jan 10, 2008 | 01:47 PM
Teufelhunden's Avatar
its def not bearings. where is the noise coming from? it could be your CV joint.
Old Jan 10, 2008 | 02:16 PM
nk2k2's Avatar
try this...cut the wheel all the way to locking on each side and go underneath and see if anything is rubbing. also if you want to check for bearing play, jack front end of car up and put your hands at 12 o'clock and 6 o'clock and check for play. hope that helps.
Old Jan 10, 2008 | 03:17 PM
wyche89's Avatar
it's hard to tell... it sounds like it's coming from the steering wheel? i dont know if that's even possible, but it's hard to tell where the noise is coming from.. definitely the front of the car.. lol
maybe i'll swap out the power steering fluid and see if that helps
Old Jan 10, 2008 | 04:45 PM
DrKlop's Avatar
Driving is the next best thing
Is it a loud noise?
Do you hear it ONLY when the wheel is cranked all the way to the side? Do you feel/hear anything strange when you are making sharp turns at speed? (30+ mph)
What about when trying to accelerate hard?
Does it make the same noise if turning in both directions, left and right?
Do you hear it more when going over bumps?
Old Jan 11, 2008 | 09:00 AM
wyche89's Avatar
Originally Posted by DrKlop
Is it a loud noise?
naa it's not that load.. you can hear it when the radio is off, but not when it's on
it gets louder as the wheel is turned farther... and no, it doesnt have the be turned all the way.. for example, if i'm waiting to make a left turn onto a perpindicular street, i can hear it when it's turned... maybe 75% of the way.. and no, i only hear it at low speeds.. i think it's just taking off from a stop and turning
yea, you can hear it then.. i don't think it's any louder, but it's still there
yup.. and when i'm in reverse turning left and right
i havent noticed, but i dont think so
Old Jan 11, 2008 | 09:19 AM
bladerunr's Avatar
I've got the same sound - i call it a groan - whenever i'm making a turn from a dead stop. i think it's the steering rack, but no one here can verify that. i've tried flushing the power steering fluid out and replacing it with synthetic but that didn't help. maybe with more people identifying the problem, we can find the cause.
Old Jan 11, 2008 | 09:51 AM
aphiguy's Avatar
It is probably the wheel bearing. I bought a 2001 Maxima SE from a dealer. and had to replace the left wheel bearing. costs u anywhere between 150 to 200 bucks..
By the way, I bought my car for 10,650 from a dealer. It was 78350K, metallic dark grey color, has Sunroof, 8way pwr driver, 4way pwr passenger heated leather seats, 17 inch wheels, relatively new tires, traction control, bose stereo, automatic climate control, auto dimming rear view mirror, carpeted trunk lid.
I may not have had the best deal. But is it a good deal??
Old Jan 11, 2008 | 12:48 PM
DrKlop's Avatar
hm... then it's not what I expected... lol (not steering bumpstops)
According to what you are describing I tend to think it's the axle, but I don't think I can say it for sure.
Is it more of a clicking/ticking sound, or "metal on metal" sound?
Old Jan 11, 2008 | 12:54 PM
wyche89's Avatar
no.. just like the one guy said above me, it's like a groaning/moaning sound
Old Jan 28, 2008 | 06:26 AM
94CobraR's Avatar
Very Weird, I'm experiencing this problem myself. It's more of a grind and I have a feeling it's either the pump or the rack. I'm not feeling anything through the steering wheel and the car turns with no issues, but it's a horrible grinding sound. First noticed it when I was going [B]Straight[B]. Don't think it has anything to do with the bearings or C/V joints or axles. Definitely in the steering area.
Old Jan 28, 2008 | 11:40 AM
CreativeSkillz's Avatar
My car makes a similar noise as well. Only seems to do it sometimes though and when it's wet, it seems to do it the most.
Old Jan 28, 2008 | 02:48 PM
1whtmax's Avatar
I have the same noise that you guys are talking about but have noticed that the car doesnt make any noise when i first start driving in the morning then after driving for a while it starts make the noise. I already had both front wheel bearings replaced with no help, the dealer also replaced the passenger side axle didnt help either. One thought was that it could be the LSD, does anyone else with the noise also have LSD?
Old Jan 28, 2008 | 02:56 PM
!PrjctMax!'s Avatar
with Nissan's quality!
My steering column "screeches" while turning, no matter if I'm stopped or moving. I don't hear anything on the highway, but city driving is just annoying! And when I say steering column, I mean steering column...like right behind the steering wheel...
Anyone have a good fix for this?
Old Jan 28, 2008 | 02:58 PM
Parthur's Avatar
It sounds more like CV joints, if the sound is only when the steering is turned more than 75% and the "weight" of the car is on the turning wheel, the CV joint may be affected.
If you lift the car and make it spin the wheels and there is not sound (humming) the bearing is ok. ( at least that is my experience )
Old Jan 28, 2008 | 03:00 PM
wyche89's Avatar
yes, mine does it and i have HLSD
!PrjctMax!'s Avatar
Mine does it all the time...whether I'm backing straight from my drive-way or turning slightly.
Old Jan 28, 2008 | 07:17 PM
daesonn's Avatar
I noticed a strange noise in my front right wheel whenever I turned right in the rain, I don't notice it when its not raining, and I don't notice it when I turn left, any idea what this could be? or if its related?
Old Jan 28, 2008 | 08:02 PM
Drockb418's Avatar
how does your cv joint look? any tears? like mine
Old Jan 28, 2008 | 08:10 PM
wyche89's Avatar
oh that's what the CV joint looks like! holy crap.. i see that thing every time i change my oil, but never knew what it was.. lol.. i don't know if mine is torn.. i'll check it out
Old Jan 29, 2008 | 09:46 PM
NisTech's Avatar
it's most likely from what you describe a vane pump (power steering pump) They get noisy by design when they wear out.
Try flushing your fluid first and adding LUCAS Power steering fluid/sealer - 2 bottles. It might quiet it down especially if you live in worm climate. This could also be a fix for guys that have pumps make noise after driving for a while.
Pull old fluid with siringe then pour the new one, then start it and do the same with the second bottle
Old Mar 13, 2008 | 07:15 PM
lowespec's Avatar
i've got a 94 max, everytime i turn left or right in an intersection i hear a clicking noise, any ideas
Old Mar 13, 2008 | 07:17 PM
SoonerFan's Avatar
Cletus
ideas?
instead of bumping a thread in the 5th gen forum...post in the 4th gen forum
Old Mar 13, 2008 | 07:39 PM
lowespec's Avatar
yeah, sorry about that
Old Mar 13, 2008 | 07:43 PM
Professor's Avatar
So these stearing bump stops, the little plastic nubs on each wheel knuckle, where can i get the nubs lol, ones missing and it makes a awful noise when turning hard and hitting a bump. also i get a creaky squeeky noise lol when i turn right.
The part i need is 40038C
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
