How to cover holes in trunk?
Old Jan 17, 2008 | 07:42 PM
stronium_95se's Avatar
I debadged my maxima not knowing the Nissan emblem had holes behind it, how did you guys cover up the holes? and theres still residue from the glue, any suggestions on how to take it off? I tried using googone, wd40 and heating it!
Old Jan 17, 2008 | 07:49 PM
Scottwax's Avatar
That's Mr. Detail to you
Heating it and scraping it with your thumbnail will get most of it, use a light polish for the rest. It may take a while, even with a buffer it took me a couple minutes to completely remove the residue. I left the "Nissan" emblem because I knew it would leave holes. If you don't want to have them filled and painted at a body shop, I'd just put it back.
Old Jan 17, 2008 | 08:33 PM
Maximized2000's Avatar
Painters tape on the outside of the trunk to cover the holes. Pop your trunk, mix some bondo up and apply some to cover up the holes from behind (make sure you put enough). Give it some time to dry up and slowly remove the painters tape to reveal the covered up holes. Now use touch up paint to cover up and your all done. If you have a system in your trunk...the bondo might fall off after a while so be careful.
I read this somewhere and I know there is a thread with pictures but I can't find it anywhere.
Old Jan 17, 2008 | 08:36 PM
Merlyn's Avatar
And... I'm out
That is really the only way to go about it, the other way that I have heard about is similar, but a bit more in depth
get a dowel rod that will fit the hole snug, from there you want to cut it to fit within the hole (to the point where it is snug from the outside, and hopefully the inside, you then put a small layer of bondo on each side, sand and paint...
Old Jan 17, 2008 | 08:40 PM
yea thats another way too but a little more risky. "sand and paint"....someone that has no idea what they are doing might mess up their trunk.
Old Jan 17, 2008 | 08:48 PM
Merlyn's Avatar
And... I'm out
That is true.... that is why I said it is a bit more complicated, but a way I personally would take (though I probably would go with some form of metal rod myself...
Old Jan 17, 2008 | 10:07 PM
SoonerFan's Avatar
Cletus
bondo
touchup paint
Old Jan 17, 2008 | 11:19 PM
Czerkas's Avatar
Is it just me or does anybody else look at where the Nissan emblem should be and still sort of see it there ...
Old Jan 18, 2008 | 12:07 AM
impact'sa33's Avatar
you can use bug and tare remover got my double side tape off real clean
Old Jan 18, 2008 | 12:21 AM
00SEMAX19's Avatar
Originally Posted by soonerfan
bondo
touchup paint
That came out clean. I might have to remove the burger finally.
Old Jan 18, 2008 | 12:35 AM
SoonerFan's Avatar
Cletus
that was my 00 and i decided that i didnt like the look with nothing there.
but i wanted something smaller....and different...so i got one off a pathfinder. its smaller and flush. it was on my 00 and now my 02.
stock 02 rear
now (smaller hamburger, SE removed, and MAXIMA replaced with A33)
Old Jan 18, 2008 | 12:48 AM
00SEMAX19's Avatar
BTW Where did you get the A33 badge? Or did you just put that together yourself?
Old Jan 18, 2008 | 01:02 AM
SoonerFan's Avatar
Cletus
put it together myself. weeks of research with different companies to find letters that were the same size and font as the stock MAXIMA
Old Jan 18, 2008 | 01:08 AM
00SEMAX19's Avatar
And? Whats it going t tak to get some of that research info?
Old Jan 18, 2008 | 01:30 AM
SoonerFan's Avatar
Cletus
right now, its own of a kind. i thought of it and did the research. i should trademark it.
if people do it, thats fine. i dont really want to give all the info. pictures should be enough.
Old Jan 18, 2008 | 10:10 AM
Armon's Avatar
I like the blacked out keyhole too
Old Jan 28, 2008 | 06:51 PM
Teaner's Avatar
2003 Nisan Maxima
Ditto Sooner i do like the key hole as well.
Old Jan 28, 2008 | 07:15 PM
SoonerFan's Avatar
Cletus
that was a must when i blacked everything else.
Old Jan 28, 2008 | 08:05 PM
Drockb418's Avatar
i feel stupid for asking but what is A33?
Old Jan 28, 2008 | 08:26 PM
SoonerFan's Avatar
Cletus
nissan chassis code for 00-03 maxima
Old Jan 28, 2008 | 08:33 PM
Drockb418's Avatar
ah now i know
Old Nov 18, 2008 | 12:06 PM
maxgen5's Avatar
I used a buffer and some light rubbing compound to get the stubborn glue off after I de-badged and used goo-gone. Worked great.
As for hiding the holes... I used blue tape on the inside and then applied Black RTV sealant and used a wet finger to smooth it until it was flush, then used touch-up paint.
I tried the tape on the outside and did not like the results.. too many air bubbles and the texture did not work. I wanted something flexible because it needed to endure what JL Audio can do to it.
I agree, I like the black key hole when there is not a backup camera mounted in it. I think I'll do that to my door key holes, since I always use keyless and won't have to worry about scratches.
REDinLV
Aug 15, 2024 12:30 AM
doctorpullit
Mar 29, 2016 11:08 AM
jonreidhead
Jan 6, 2016 09:38 AM
uttadms31
Sep 30, 2015 05:24 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
