Throttle Position Sensor?
Old Feb 8, 2008 | 09:14 AM
Dynasty47x1's Avatar
Yesterday when i was driving on the highway I went to pass someone. I passed them i was doing about 85 and i let off the gas. Was at 4k and my rpms dropped all the way back down to 1k like the car was idle and when i pressed on the gas it would jerk back up to 4k. I did this twice by accident when i realized what was happening i tried not to let off the gas until i had to until i got home. And the car slipping into neutral. Would that be a throttle position sensor issue?
Old Feb 8, 2008 | 09:49 AM
pmohr's Avatar
No more Maximas...
Any codes?
Old Feb 8, 2008 | 10:00 AM
Ill go to advance after work and get the codes pulled either today or saturday and post them up.
Old Feb 8, 2008 | 10:35 AM
Puppetmaster's Avatar
Sounds more like a slipping tranny and not so much the TPS or APPS, but we'd have to get more details.
Old Feb 8, 2008 | 12:26 PM
I will get the codes pulled and what details would you need
Old Feb 8, 2008 | 01:13 PM
jasonmax's Avatar
sounds like a tranny problem, not the engine.
Old Feb 8, 2008 | 01:34 PM
its running fine now after i let it switch also i had switched overdrive off when it happened
Old Feb 9, 2008 | 02:41 PM
wyche89's Avatar
after you let what switch?
Old Feb 11, 2008 | 12:01 PM
BMWHIGH1's Avatar
you must have an 2000 or 2001 because 02 and up has an automatic overdrive so it gets rid of the annoying button.
Old Feb 11, 2008 | 01:56 PM
jasonmax's Avatar
I always think the O/D on 5.5th is 3rd gear.
4th gear is the O/D gear, O/D means gear ration less than 1.
Old Feb 11, 2008 | 02:23 PM
Yes i have a 2000 just the 02 sensor codes were pulled. I checked the transmission fluid looked fine nice and red and smells like transmission fluid extremely fresh. But it hasn't done that again but when its hot and i drive hard and stop and go it will slip into a neutral state (which i havent had happen since i removed my gab mod and had my cat replaced) until i put it in neutral then back into drive or turn the car off then back on.
Old Feb 11, 2008 | 05:18 PM
01GoldieLox's Avatar
same problem
wats up fellas.. I'm new to this site but i have a 01 maxima gle and i have a similar problem but when i hit the gas my car kind of putters and doesnt have full power.. what do u guys think the problem is
Old Feb 12, 2008 | 08:42 AM
1sexyleo
lol...........i guess my tranny has done it all. had the same experience last fall. i was at 3k rpm and let off the gas it dropped to 1k....hit the gas again...didnt pick up speed until i was back at 3k rpm....lol
i think ive seen it all.......
nissan should have a recall on their automatic transmissions
Old Feb 12, 2008 | 02:24 PM
ShIft_uR FacE's Avatar
mine sometimes drops down to 1k after accelerating but it always picks up speed once i touch the gas...more of a spike downward or a bounce..
Old Feb 14, 2008 | 09:32 PM
Thats exactly what happened it happened today on the highway again when i passed somebody allways after im in stop and go traffic and its hot.
Old Mar 3, 2008 | 06:28 PM
Grand_hustle17's Avatar
you think that button is annoying, i actually like it (same category as your post-nothing to do with the topic)
Old Mar 3, 2008 | 06:34 PM
what a coincidences i was going to start a thread with the exact headline, unlike the person that started the thread, mines drag the shift points from 1st-2nd under WOT but when i drive regular it doesnt, im thinking TPS and not tranny, any similar case, im getting codes pulled tomorrow at nissan
Old Mar 3, 2008 | 06:38 PM
they really should have a recall, arent you at 4 now, damn we're tied, i might be going on 5 with my problem... funniest thing is 24k (clint) had his way longer and drive more and just as hard and never had to replace a tranny (guess its the luck of the draw...) or is it ?
Old Mar 4, 2008 | 07:30 PM
sooooo... has anyone came across something similar as post 17
Old Mar 4, 2008 | 07:34 PM
SoonerFan's Avatar
Cletus
100% bad TCM (tranny control module)
common and known problem on here
had to replace mine on my 00...after it wore the tranny out and had to replace that.
TSB - http://maxima.theowensfamily.com/tsb/NTB00-039a.pdf
Old Mar 4, 2008 | 07:52 PM
thanks bro, you rule (too bad not on COD4)
Old Aug 8, 2008 | 01:05 PM
RuffRyder2G's Avatar
I'm having a problem with my car as well. I live in the bahamas and have an 02 SE. When I start it, it just keeps reving really high and when i try to put it in gear it just stalls and shuts off. WTF. I'm so frutrated.
Old Aug 11, 2014 | 06:18 PM
G3Nis's Avatar
Sorry to pull up a 6 years old forum.
Had a similar problem, but in my 03.
I was driving on the highway in 6th and lost power, car went to idle even though I was flooring it, then 5 seconds later regains power and revs up. Then does the same thing where it idles then regains RPMs.
I put in neutral and revs up to 3k then slightly sluggish.
If I let it idle on the side of the road, will reset in 5-10 minutes then I can drive like normal for the next 30-40 miles, where it happens again.
TPS vs MAF vs fuel pump?
No error codes.
mvm062
Nov 30, 2020 09:00 AM
msellas
Sep 23, 2015 09:16 PM
220k+ A32
Sep 23, 2015 03:38 PM
JoshG
51
Sep 21, 2015 10:41 PM
bumpypickle
Sep 20, 2015 08:22 AM
