TCM location????
Old Feb 10, 2008 | 04:04 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
TCM location????
Anyone knows....? Does anyone has a Picture on how it looks...?????
Old Feb 10, 2008 | 04:26 PM
Love_00_Max's Avatar
If I am not wrong it is behind the radio console.
Old Feb 10, 2008 | 05:23 PM
Lontar1's Avatar
That's what I was thinking....
Old Feb 11, 2008 | 07:38 AM
pmohr's Avatar
No more Maximas...
For an '01, anyway.
Old Feb 11, 2008 | 03:18 PM
Scottwax's Avatar
That's Mr. Detail to you
Hey Lontar-when you pull out the TCM, post up some pictures. The diagram is great, but nothing beats actually seeing pictures.
Old Feb 11, 2008 | 05:53 PM
Lontar1's Avatar
I will be buying a new TCM to fix the issues I have with my tranny really soon so I will post a full write up on HOW to remove it and instal a new one with pics of course....
Old Feb 11, 2008 | 07:00 PM
cefiro80's Avatar
cant wait I have an 00 that I think needs a new tcm so a writeup will be greatly appreciated.
Old Feb 11, 2008 | 07:07 PM
NmexMAX's Avatar
dot dot dot ...
It's actually really straight forward. Remove some panels, unplug, replug, reattach panels. done.
Old Feb 11, 2008 | 07:44 PM
A33 VQ30DEK's Avatar
i have one if you want to buy it.
Old Feb 11, 2008 | 08:07 PM
djfrestyl's Avatar
Suspension Yoda
YGPM.
Old Feb 11, 2008 | 08:38 PM
Scottwax's Avatar
True but seeing pictures makes it a real no-brainer.
Old Feb 11, 2008 | 11:37 PM
yeah but the diagram shows right where its located. No need for a real picture.
Old Feb 12, 2008 | 05:53 AM
MacGarnicle's Avatar
What kind of issues?
Old Feb 12, 2008 | 06:20 AM
NmexMAX's Avatar
dot dot dot ...
Sometimes it's nice to be able to follow a diagram and use some of that grey matter.
Old Feb 12, 2008 | 06:45 AM
sciff5's Avatar
I think I may have the same issue. Tranny has been slipping a lot in the winter. When it warms up (as in temp outside the car) though the tranny is normal.. very wierd
Old Feb 12, 2008 | 06:55 AM
Scottwax's Avatar
No, not when you have as little grey matter as I do.
Plus, with pictures, we can all see how everything comes apart to get to the TCM. The ECU in my Accord was easy to get to, just had to pull the carpet up on the passenger side and remove a panel. Digging into the console area is more involved.
Old Feb 12, 2008 | 07:07 AM
1sexyleo
this is somewhat what it looks like. it is attached by 2 nuts. after you unscrew them u lift the brackets off the bolts. its smaller than the ecu. u might have to remove the panel where the shift lever is. i removed and replaced mine in about 20 minutes. make sure u wear rubber gloves to prevent any static shock that could fry ur tcm.
i have a 02 tcm if u wanna buy it for $75.
Old Feb 12, 2008 | 07:18 AM
1sexyleo
if you remove the panel below it should be right behind it and towards the back.
Old Feb 12, 2008 | 09:29 AM
slag's Avatar
Is the TCM for a 2000 max the same as one for a 2000 infiniti I30?
Old Feb 12, 2008 | 03:10 PM
NmexMAX's Avatar
dot dot dot ...
Old Feb 12, 2008 | 03:47 PM
Lontar1's Avatar
The issues are..... Car moves change from 1st to 2nd.... everything goes well... change to 3rd and....everything goes well, then, the tranny looses it gear.. it goes back to 1st and stays there while driving... then it goes back again to 3rd after you push the accelerator or turn off the car and turn it back on.......
Old Feb 12, 2008 | 03:50 PM
Scottwax's Avatar
Thanks for the pictures, Leo.
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
fx4five
Oct 1, 2015 04:58 AM
