P0160
Old Feb 14, 2008 | 12:51 PM
chadsexington's Avatar
P0160
I'v searched through the site and haven't found an answer for this. FAQ section is not functioning propertly ..
Got SES...P0160( bank2 sensor 2)...Do i replace both rear o2 sensors and reflash the ecu? my car is 01, 120KM(not milles)on the clock and no mods.
Any input much appreciated
Old Feb 14, 2008 | 03:30 PM
pmohr's Avatar
No more Maximas...
Why not just replace the O2 you're getting the code for, clear the codes and see if you have any more problems?
Try the simple stuff first...
Old Feb 14, 2008 | 03:39 PM
also could it be as a result of injection cleaner stuff that i'v put in?
Old Feb 14, 2008 | 03:44 PM
SuperStasiu's Avatar
just get a dual band o2 simulator for 30 bucks and your set
Old Feb 14, 2008 | 06:47 PM
MacGarnicle's Avatar
O2 sensors DO serve a purpose you know...
Old Feb 14, 2008 | 06:58 PM
pmohr's Avatar
No more Maximas...
The downstreams don't. Not to anyone on here, anyway.
Old Feb 15, 2008 | 06:59 AM
Exactly, no need to spend a hundred plus bucks a sensor that doesnt do anything when a 30 dollar simulator can fix it, those of us with headers run these and have no cel, or ses lights
Old Feb 15, 2008 | 09:00 AM
jkayca's Avatar
Unless you want to know if your pre-cats are working. Could be a problem if your local e-test centre hooks up an exhaust sniffer rather just checking out codes.
Old Feb 15, 2008 | 09:31 AM
pmohr's Avatar
No more Maximas...
Not if you have a fully functioning converter, it won't be a problem.
Old Feb 15, 2008 | 10:55 AM
NmexMAX's Avatar
dot dot dot ...
If your primaries are gone or dead, they DO serve a purpose.
Old Feb 15, 2008 | 11:01 AM
pmohr's Avatar
No more Maximas...
You guys and your newfangled technology. I don't have any O2 sensors...hell, I don't have any exhaust. I run open heads on my car...
Anyway (back on topic), do they act as a 'backup' of sorts? I imagine that doesn't work all too well for the guys running headers with O2 sims there...
Oddly enough, Merlyn has been running for the past year with a downstream sensor in the front bank (idiot mechanic that installed them) with the only adverse effects being a rough idle and a CEL.
Old Feb 15, 2008 | 11:23 AM
NmexMAX's Avatar
dot dot dot ...
Yeah, back-ups. I didn't feel like installing my O2 sims yet, nor extending my primaries, so I plugged my secondaries into the primary port. SES, yes, closed loop malfunction codes, yes, city MPG 17, highway MPG 26, same as with the primaries.
Old Feb 16, 2008 | 06:50 AM
jkayca's Avatar
That's true. But the main cat doesn't function at 100% until it is warmed up. That's where the pre-cats come in. I guess it depends on how they do the test.
vdubdezl
Jan 27, 2014 08:32 AM
thisasian
Dec 21, 2006 02:48 PM
Edward Lee
Mar 25, 2006 08:36 PM
Link112
Jul 22, 2004 02:00 PM
