Bolt almost rounded
Old Feb 15, 2008 | 03:43 PM
01SilverMaxima's Avatar
Bolt almost rounded
Ok so I went to change my tranny fluid today finally. I have 01 SE 3.0L 5MT with 86K miles on it. I just bought the car about 6 mths ago. The drain bolt is impossible to get to with anything other than an open end wrench, as i am sure you all know. Problem is is that the bolt is rusted BAD.
I PB Blasted the heck out of it, let it sit for a while then went at it. The bolt does not wanna break loose, it is starting to round off. Any ideas short of taking it to the stealership to get them to take it out for me?
Old Feb 15, 2008 | 03:45 PM
upstatemax's Avatar
Vise Grips
/ thread
Old Feb 15, 2008 | 03:51 PM
ah thanks, never thought of that. Guess i had better get a new bolt before trying to tackle this. did yuo have the same prob?
Old Feb 15, 2008 | 03:58 PM
NmexMAX's Avatar
dot dot dot ...
IMO, it's general practice to use VG's whenever you have a rounded bolt/but. Obviously be prepared to replace it with a new one when finished.
Old Feb 15, 2008 | 04:14 PM
Well i noticed there is what i believe to be a sensor going into the bottom of the tranny. Plastic piece with wire going into it, and the same level if not lower than the drain plug. Thoughts on removing this instead?
Old Feb 15, 2008 | 05:02 PM
freshv6power's Avatar
check out this thread in the fluids section http://forums.maxima.org/showthread.php?t=164708
Old Feb 15, 2008 | 05:08 PM
NisTech's Avatar
i use a socket with an impact gun and go really light at it (variable throttle). If not use a socket with an extension and a wrench 1/2 inch and push against the pan hard to seal even and turn. that way it won't slip. 12 point wrench will round it for sure
Old Feb 15, 2008 | 05:21 PM
Update: Taking out the plastic peice was easy as pie. The fluid drained in about a 1/2 a second. LOL I read that thread, just for shoots and giggles. I already knew how to change the fluid. The how to didnt show me anything useful unless I overlokked it. thanks for the quick responses everyone
Old Feb 15, 2008 | 09:53 PM
Sorry I didn't link you directly. This was in the first post under the 95-01 instructions. http://www.cardomain.com/ride/200625/7
Old Feb 16, 2008 | 08:43 AM
thanks anyways v6, i had read that first link but didnt read the second one until just now. I couldve saved myself about 20 minutes of frustration had i read that one as well. Figured it was more of the same. and my post that you quoted shouldve read "LOL. " I want LOLing at you btw.
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
