Truax SFC finally installed!!
Finally got he SFCs installed at ATX Motorsports in Bergenfield, NJ. For all the locals, great shop! They do everything from body to fabrication!
During the install they said one of the rails was bent. Probably from manufacturing after Truax did the tac weld, and when they went to weld everything else the welding pulls on the metal and thus was bent?
So with the rail straightened out, everything went on smooth. The installer also recommended that the center brace be welded to the factory brace for extra rigidity. I said why not since everything is still removable.
Pic below of what I'm talking about. Black piece is factory, gray primered piece is the Truax center brace..
First drive home = what everyone said, car feels much firmer over bumps, and as close to a BMW as you can get
SFCs FTW
I just have the side rails, and not the cross member, but it still made a huge difference. Cost me <$100 to have a muffler shop weld it on. Since it wasn't a performance shop, I had to show the guy how to orient it and where to weld.
If I had to do it all over again with a stock car, this would be my first mod
the difficult part about the installs is that the car's unibody rails aren't necessarily straight either. I know one of mine was slightly bent so they had to alter the truax rail to fit it better...
But when it comes to welding I dont know that at all and cant do it. When I dont know how to do something, I become extra paranoid because I cant talk detailed enough to keep them from pulling something over on me.
I'm thinking about getting SFCs as well.. did it do anything for your cornering stability? how about the the car losing composure when hitting bumbs going around a bend? did it do anything for any interior squeaks, rattles, or other noises you may have had?
The car feels more stable going over bumps, doesn't shake around any more. Cornering? Don't feel much difference. Didn't have rattles to begin with so no improvement there.
I don't know if this observation makes sense, but driving around more last night, the car's "belly" feels heavier and more planted when making fast turns. Makes some sense to me as the SFCs added approx. 40lbs of weight.
where can i order a set? or at least whats sfc stands for. my car feels awfully loose over bumps and i seriously need to stiffen up the ride and the chasi or my struts are blown i dont know but still tell me where to get these.
http://truaxmotorsports.com/products/
Im considering these from the positive review. I'm on Tein SS coilovers which is impressive.. but i have the rattles and could always use a more solid, firm, ride.
n3985: did you get the full bracing (Side rails/crossmembers) for 325 or the other option for 225??
http://forums.maxima.org/showthread.php?t=546291
I just need to get mine installed now after a year of them sitting in the garage.
considering...where I am with my set up...I mind as well ...just spend a fraction more for these. The only thing that held me back was the quoted install cost of variying shops...$300~$600..but the quote from n3985 especially with the shop doing the rubber UNDER COATING! ...makes me way more motivated...I am going to call CSE engineering to and see what they will quote...to compare.
SFC = Sub Frame Connectors
You can buy a can of spray on rubberized coating for less than 10 bucks. Call around to your local muffler shops and find one that will charge $100-$200 for the install. (those are the prices out here, anyway)
I also recommend spening $5 and buying a can of primer, so you can primer all the rails before install. Then take remaining, prime the welds again. Followed lastly by rubber undercoating which as stated is only $5-10.
Dude, it is less than half way down on the first page of the GD forum:
maybe i interpreted that wrong..
from reading that it reads like the shop did all of the above..though I figured a shop typically wouldnt do that extra spray stuff.
burnurass= How much did they charge you?
n3985= $240 total, with the extra bit of welding, priming the welds, and spraying the entire thing with rubberized undercoating.
Their # is 201-385-1003, ask for Narvin.
hey nan,
congrats on the install. Im glad it worked out for you.
Anyways, the price you quoted was on point when i got a
quote there too.
I'm still debating on the adding the SFC... mayb ill do it when im
back in the states.
As for the group deal... burnurass let me know if your gonna get it
installed. Mayb we can get install at the same time for discount.
-Anthony
quote there too.
back in the states.
-Anthony
hey nan,
quote there too.
back in the states.
-Anthony
quote there too.
back in the states.
-Anthony
If we have a definate date maybe we can have Puppetmaster Join us for the group deal..he's asina and likes good deals too.
if ur thinking about getting these read the reviews, i absolutelty love mine. if ur a suspension junkie you just have to have them hands down. perhaps not a word of difference, but deff noticable.
mine went on pretty easily, little bending but nothing drastic.
Mar 12, 2020 12:06 AM
MaxLife17
Jun 27, 2019 01:37 PM
lowpost99
Sep 8, 2015 05:06 AM
would appreciate it, i couldnt locate...
