warpspeed y-pipe
Old Feb 18, 2008 | 03:49 PM
dAAmax's Avatar
warpspeed y-pipe
hey guys...alright i just got put in a warpspeed ypipe and OMG now my car sounds soo rice its not even funny. i hate the sound of my car now. is there anything that i can do to reduce the noise? thanks
tom
Old Feb 18, 2008 | 05:10 PM
dAAmax's Avatar
after reading up on this.. i dont no what to do... get rid of my muffler or get a bigger resonator, but i dont want to reduce performance levels. what should i do?
Old Feb 18, 2008 | 05:27 PM
Scottwax's Avatar
That's Mr. Detail to you
Do you have the stock muffler or aftermarket?
Old Feb 18, 2008 | 05:30 PM
wyche89's Avatar
as long as you didn't alter your stock muffler, changing it won't do anything.. the noise is probably coming from the flex pipe.. they've been known to have leaks and make kind of raspy noise on some y-pipes
the stock muffler is a great performer, and any perofrmance gains from an aftrmarket muffler would be minimal.. if you have an aftermarket muffler, try going back to stock and see what that does
Old Feb 18, 2008 | 05:33 PM
dAAmax's Avatar
yeah i got a bosal muffler...it was a nice deep noise, i loved it and i heard the intake... now right under me i hear like fucn crazy *** noise. i cant hear my intake anymore and it sucks.. idk what to do.
Old Feb 18, 2008 | 05:35 PM
wyche89's Avatar
it's probably the flex pipe.. especially if you hear the noise coming from directly under you, which is where the y-pipe sits.. i don't know of any way to repair a leaky flex pipe, but i'm sure there is one
dAAmax's Avatar
like my car kinda sounds like a dirt bike... its horrible.
Old Feb 18, 2008 | 05:37 PM
dAAmax's Avatar
alright.. is that where the resonator sits?...should i get a bigger one to reduce noise or u think i might need a new flex pipe cuz its leaking?
Old Feb 18, 2008 | 05:41 PM
Nopike's Avatar
Did you do the install yourself. If you did not make solid connections and use the correct new gaskets that can also cause an exhast leak. The Y-Pipe itself should not cause your Maxima to sound that much different.
Old Feb 18, 2008 | 05:44 PM
dAAmax's Avatar
yeah.. i got it done at maximum tuning where jeff does great work and he put one new gasket in and he said thats all it needed the other were fine. I asked him befor the install and he said it shouldnt make the car much louder at all and its insanely louder.
Old Feb 18, 2008 | 05:52 PM
reeloop's Avatar
+1 flex pipe
go to a muffler shop and have it replaced
Old Feb 18, 2008 | 06:18 PM
dAAmax's Avatar
how much do you think the flexpipe would run me?
Old Feb 18, 2008 | 06:57 PM
wyche89's Avatar
i have no idea.. shouldn't be that much.. its a flexible piece of metal
Old Feb 18, 2008 | 07:00 PM
NewfoundlandDud's Avatar
You can also check for contact with your heat shields.
Does the sound kind of resemble a vibration? This is what happened to mine, as well as numerous other members on here (There have been many posts on this topic).
The "Hangar" on the pipe that sits in the original rubber bushing actually pushed my whole exhaust back & down because it was on too much of an angle away from the y-pipe. This caused a couple of things on my exhaust to vibrate off of heat shields & other things.
It does sound like a crappy flex section (Which Warpspeed are famous for), but this is another thing to consider........
Old Feb 19, 2008 | 05:47 PM
NaztyMax's Avatar
I just did mine last weekend, hate the sound too! Gonna check connections this weekend cause it sounds like a wicked exhaust leak right now. But I may have to go the route of a new flex section or at least wrap it for now. (YES, I KNOW WRAPPING LEADS TO PREMATURE DEGENERATION, but I did the whole y-pipe except flex already and just hope it will last me the next 2-years that I'm gonna have the car)
Old Feb 19, 2008 | 05:58 PM
dAAmax's Avatar
yeah..at idle it sounds aewsome tho..really nice tone...but when u drive away inside the car right below u it sounds like a crazy *** leak. i hate it.. but i had one of my boys drive around by me and it doesnt sound that bad on the outside...mostly just inside the car, but i cant deal with the sound..gatta c what i need to do to get rid of it.
Old Feb 20, 2008 | 07:24 AM
NmexMAX's Avatar
dot dot dot ...
There's the obvious flex section issue. Also, no aftermarket y-pipe come equal length any more, so I would say that is a problem as well, especially if your catback is not stock.
Old Feb 20, 2008 | 01:16 PM
MerlotMax's Avatar
The hanger can be reshaped, are you sure you don't have a leak somewhere? I have no sound issues with my warpspeed y-pipe. The flex is part of the y-pipe. A muffler shop might be able to weld in a new flex section.
Old Feb 20, 2008 | 07:55 PM
dAAmax's Avatar
yeahhh fellas...just took it to maximum tuning again today and the dam flex has a leak. ganna cost around 150 total to fix everything. woww this sucksss, but at least i found the problem.
Old Feb 21, 2008 | 02:37 PM
MerlotMax's Avatar
Did you buy this pipe used? If new, Dallas should cover any warranty. Glad you found the problem.
Old Feb 21, 2008 | 02:40 PM
The Law's Avatar
I R The Law
And that is why you don't buy from warpspeed
/thread
Quickywd01
Sep 21, 2016 09:36 PM
lrb6805
Sep 30, 2015 08:12 AM
lrb6805
Sep 17, 2015 04:49 PM
