Engine wont rev past 1500rpm
Sounds good. So do feel we are ok to drive our Maximas the way they are? Did you clear your check engine light or did it turn off yet? Since I tend to think it was a cold weather thing I'm debating if I need to do anything or if I should just reset the ecu. What did you do?
In my situation the car would not go beyond 1500RPM, I would unplug the TB connector, plug it back in and the car would be good for 3+ weeks. Then it could come back again.
However; if the car cuts out while you are on the road and does not let you go beyond 1500RPM it can be dangerous. I am not sure of the controller programming, but if it can go into limp mode *anytime*, I would fix it before taking the chance again....
It’s more a function of sensor feedback (TPS/APPS) vs start-up readiness.
Checking the codes would be the best way to start getting to the root of this problem. The codes should steer you in the right direction.
I always make sure to carry a few bottles of the antifreeze with me now, although I haven't had the problem happen since.
bryants95max
Oct 2, 2015 12:52 PM
