03 Headlight slightly leaking
Old Mar 2, 2008 | 04:55 PM
95 Maxnout's Avatar
I noticed recently that I had some condensation building up in my HID passenger side headlight so I opened up the back of headlight and used a blow dryer to clear it out.Today I finally got a chance to wash my car and as soon as I was done I checked the headlight and sure enough I saw a few drops of water forming on the inside of the lens.My question is,should I remove the headlight and reseal it entirely,and what do I use to reseal it with.Any info is VERY APPRECIATED...Thanks.
Old Mar 2, 2008 | 05:04 PM
skidz88's Avatar
I used this stuff called Window Weld, it's black and looks like tar but it works REALLY well. Comes in a tube with a Nascar logo on it lol.
Old Mar 2, 2008 | 05:58 PM
95 Maxnout's Avatar
^^^Thanks man.Where exactly would I need to reseal headlight since I'm not sure where it is leaking.I know for sure there are no cracks in lens.
Old Mar 2, 2008 | 06:12 PM
daesonn's Avatar
i recently used silicone to reseal my leaking tail lights...obtained...anywhere.
Old Mar 3, 2008 | 04:03 PM
Squirrel82's Avatar
I used silicone.Dunked the headlight facing up in the bathtub to find the leaks.Took the bottom electic black box off.Dont know the name of it.
Old Mar 3, 2008 | 06:48 PM
skidz88's Avatar
Probably most auto parts stores would carry it, or some other variant of it.
Old Mar 3, 2008 | 06:55 PM
SoonerFan's Avatar
Cletus
i had a bad leak after i cleared my HIDs. used silicone on all the edges and it went away.
something else i did - weather stripping along the top where the hood meets the headlights. most water enters from there since its the one place that has a gap. that seals out the water. side benefit - it also seals out the air that enters there and causes the hood to flutter at speeds.
Old Mar 3, 2008 | 07:51 PM
PearlWhtMaX2000's Avatar
when i had a leak, i just put my headlights in the oven preheated to 300 for like7 min, than took them out, and pushed the back and front together tightly.
Old Mar 3, 2008 | 11:12 PM
95 Maxnout's Avatar
Thanks everyone for the much appreciated info.I'll let you all know how it turns out.
Old Jun 17, 2008 | 01:43 PM
hi-tek22's Avatar
is it unusual for condensation to build up on the reflector lense above the HID bulb?
THAT IS THE ONLY place where water or condensation seems to be building up at...and its either killing my 8k bulb or the condensation is making it seem a lighter purple instead of the the deeper purple from an 8k bulb
(could any one shed some light on this, because i don't see where condensation is coming in anywhere else)
oh btw sooner, what size stripping did you use? that sounds like a good idea
It's a ballast, and ignitor
AaronL
Nov 15, 2020 11:52 AM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
minsbang
Sep 11, 2015 08:48 PM
Hdnseek
Sep 9, 2015 05:55 AM
