major power loss
Old Mar 4, 2008 | 08:09 AM
allblackmax96's Avatar
major power loss
my friends got an 01 AE 5speed with 110,000 and recently he told me the cars not performing right. i took a ride and the thing is a dog, i had a 96 auto that wouldve killed it (just a comparision). it feels very very sluggish. noticed a hissing under the hood, a coil was disconnected, after we reconnected it, it still felt the same. it doesnt rev easily. anyways just curious if any else has experienced something like this. any input helpful. thanks
Old Mar 4, 2008 | 08:20 AM
Fang_DH's Avatar
Any codes? Was the hissing stopped after you reconnected the coil?
Old Mar 4, 2008 | 08:51 AM
steves01max's Avatar
MAF, notorious especially at that mileage
Old Mar 4, 2008 | 09:36 AM
NmexMAX's Avatar
dot dot dot ...
Codes would be nice, but possibly a MAF &/or coil(s)
Old Mar 4, 2008 | 09:38 AM
jasonmax's Avatar
vaccum leaks?
Old Mar 4, 2008 | 09:44 AM
NmexMAX's Avatar
dot dot dot ...
Would explain the hissing sound.
Old Mar 4, 2008 | 11:46 AM
Fang_DH's Avatar
Originally Posted by jasonmax
vaccum leaks?
thats why I was wondering if the hissing went away. A vaccum leak could easily rob the engine, as well as a bad MAF.
Old Mar 4, 2008 | 07:23 PM
there was still a hissing, but it was night so i really couldnt see too much, i was listening around and it sounded like it was coming from the throttle body area. it did have a code for 02 sensor bank 1 sensor 2 malfunction. but i cleared it and just confirmed with him that it hasnt come back on. not sure about that one. so has anyone else experienced sluggish performance before there MAF went?
Old Mar 4, 2008 | 07:30 PM
SoonerFan's Avatar
Cletus
ive had a MAF go bad with no SES or code
Old Mar 4, 2008 | 07:32 PM
NmexMAX's Avatar
dot dot dot ...
Check for air intake leaks. If you have an aftermarket intake, the slight hiss might be caused by the intake.
Old Mar 5, 2008 | 01:17 AM
lildoggs's Avatar
I have the same problem with my 03. It feels very sluggish and pings after 1,700 rpm's but no hissing sound. The engine doesn't respond as quick as it use to when I accelerate. I replaces the Mass airflow sensor, cleaned the valves and fuel injectors as well as the fuel line, replaced the fuel filter and replaced the spark plugs, but nothing seems to help. If you figure out what the problem is let us know.
Old Mar 5, 2008 | 07:25 AM
stock intake, is it possible that his rings are gone, that would explain the power loss, he also said his MPG is poor? ill test the maf and try to find that vacuum leak and go from there. thanks for the help. when i find the problem (hopefully do) ill let u know what it is.
Old Mar 5, 2008 | 08:13 AM
phatboislim's Avatar
CLOGGED CATALYTIC CONVERTOR. mine performed the same way and one day that cat just 'blew it self out' and cleared out whatever had it clogged and it performs great now. i still need to renew my whole catback system and replace my o2 sensor...but..the cat convertor is where you should start
Old Mar 5, 2008 | 08:34 AM
soccerplr19's Avatar
i have the same problem, everytime im accelerating , the car lags a little and then while the rpms are goin higher the car gets back to normal at 3k.
Old Apr 10, 2008 | 12:58 PM
gasper's Avatar
just had plugs replaced and the starter.The car was fine before these chages only the starter had given up.96 maxima can not accelerate to even 60.big problem.Help please
Old Apr 11, 2008 | 11:01 AM
NmexMAX's Avatar
dot dot dot ...
Dude, seriously.
Post in here:
http://forums.maxima.org/showthread....389852&page=39
TallTom
57
Oct 14, 2025 05:16 PM
aw11power
Oct 10, 2021 04:57 AM
leatherneck
Sep 30, 2015 09:16 PM
zmcneely13
Sep 26, 2015 02:26 PM
