Exciting Keyfob Thread
Old Mar 4, 2008 | 05:33 PM
Deckdout2's Avatar
Play with my balls
I wonder if we can get this 6th Gen keyfob programmed to work with our 5th & 5.5gens. hmmmmm? hmmmmmm?
Borrowed pic from 6th gen thread.
Old Mar 4, 2008 | 05:35 PM
NmexMAX's Avatar
dot dot dot ...
Only 1 way to find out
Old Mar 4, 2008 | 05:56 PM
n3985's Avatar
大陆弟弟
Nope, I already tried with 06 M45 remote
Old Mar 4, 2008 | 06:00 PM
SoonerFan's Avatar
Cletus
i had thought about this too because it looks better.
it may work on a 5.5 but my only concern was the fact that those keys do everything since you dont have to but the key in to start it. so it has a chip and other stuff to work on a 6th gen. go ask a dealer if they can program it.
Old Mar 4, 2008 | 06:35 PM
02MAXZIMA's Avatar
the only problem i see with that, is the fact if you can get the key programmed. you would have to take it out of the I-Key fob every time to use the key. i know that the 07 up Maxima and 07 up Altima I-Keys will not work with one another. the main reason i think it is not going to work is the key fob is a different frequency.
Old Mar 4, 2008 | 08:59 PM
Deckdout2's Avatar
Play with my balls
hmmmm, interesting points. I'll check it out some more, but if we can get just the remote part to work and not touch the immobilizer chip then I would think we'd be in business. I'll pick one of if I happen to see one dirt cheap or try another fob. I can see how the I-Key part would pose a problem, but all I want are the buttons to work. Will update if I find more info or something else that looks as good and works.
Old Mar 4, 2008 | 09:10 PM
Deckdout2's Avatar
Play with my balls
If anyone has this, try this programming method. I've found a few minor different methods, but this seems to be the most universal.
Old Mar 5, 2008 | 07:53 AM
jkayca's Avatar
There's this one
Almost the same but with some more timing info. I.e. must do such and such withing 5 seconds. That piece of information seems to be missing from yours.
Old Mar 5, 2008 | 05:37 PM
nsnrider's Avatar
I also believe that to be the case, I wish I had one of these lying around so I can mess with it a bit, maybe take out the main chip and swap it in here or use the old internals and swap them if they are roughly the same size?
Not sure on the size difference since I never actually say the new fobs yet.
Defenitly a good looking fob though.
Old Mar 5, 2008 | 05:42 PM
Deckdout2's Avatar
Play with my balls
I picked one up fairly cheap on eghey. Will mess with it and see what I can do. If it doesn't work out I'll just resell it. No harm no foul.
Old Mar 5, 2008 | 05:50 PM
2002AltimateV6's Avatar
The method posted by Deckdout2 worked just fine for my Altima. Thanks man! Had an extra key-fob laying around from my automatic Altima (traded it in, forgot to give them over) and the one that came with the car originally had broken. So I just went out, did the 6 key in & out, blinked twice, put the key to ACC and pressed the button, nothing happened this time.. but I then opened the door and played around the with the remote. It did it everything. Opened, locked, alarm, opened windows, opened all locks by pressing the unlock button twice. THANKS!
Old Mar 5, 2008 | 06:02 PM
Deckdout2's Avatar
Play with my balls
That's what I'm here for.
Old Mar 5, 2008 | 06:23 PM
02MAXZIMA's Avatar
the way we program the I-keys at work are. the 07+ Altima's you need consult 3. The 07+ Maxima's require Consult 2. considering u can not use the altima's I-keys on maxima's or vice versa. our best bet would be to try the Maxima's I-key.
i have a couple spare 07+ altima I-Keys at work.I will try to see what happens.
Old Mar 5, 2008 | 07:03 PM
Deckdout2's Avatar
Play with my balls
Sweet, thanks for the lookout.
Old Mar 6, 2008 | 11:14 AM
sergey85's Avatar
anyone know about those keyfobs like on audi and benz where you press a button and the key comes out fromn the side would those work or too much work
Old Mar 6, 2008 | 11:57 AM
Deckdout2's Avatar
Play with my balls
Old Mar 7, 2008 | 03:32 PM
Manda_Max's Avatar
You guys are on to sometihng. It would just be neat to have that new keyfob.
I have never used it other than to keep in my pocket and push the button on the door handle to unlock the car......but Im intersted to see what you guys find.
Old Mar 11, 2008 | 06:30 PM
02MAXZIMA's Avatar
well today i tried the 07+ Altima I-Key at work and it did not work. might still have a chance with the Maxima I-Key. just need to get my hands on a set.
Old Nov 18, 2010 | 04:28 PM
shdwonthsun's Avatar
hate to rez this thread, but did anything ever come of this? i don't need it for the ignition system, but id like to have the remote part working.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
mkaresh
Mar 12, 2018 06:48 PM
