what cats to replace?
Old Mar 5, 2008 | 06:44 PM
hotstartup's Avatar
what cat can we replace the easiest without throwing any codes ( wanna replace with a test pipe) thanks.
Old Mar 5, 2008 | 07:09 PM
SoonerFan's Avatar
Cletus
huh?
only main cat can be replaced with test pipe...other two are part of exhaust manifold and requires headers to remove
Old Mar 6, 2008 | 03:17 PM
hotstartup's Avatar
thanks sooner. Will that throw any codes in case in sensors are affected? performance gains worth it?
Old Mar 6, 2008 | 03:21 PM
SoonerFan's Avatar
Cletus
just a test pipe?
possibly
no
Old Mar 6, 2008 | 03:48 PM
Darktide's Avatar
if you replace a cat with a test pipe you will get codes without a doubt.
Old Mar 6, 2008 | 04:06 PM
spdfreak's Avatar
Wrong. Only fed spec because they have an o2 after the cat.
You can get an o2 simulator if you don't want a CEL.
Old Mar 6, 2008 | 04:28 PM
MintVQ35's Avatar
No gains to be had unless your cat converter was clogged, if so I'd just replace it with a high flow unit.
Old Mar 6, 2008 | 05:00 PM
SoonerFan's Avatar
Cletus
now days, cats are not as restrictive as in the past so a test pipe does nothing.
Old Mar 6, 2008 | 11:54 PM
spdfreak's Avatar
Unless your turbo.
Old Mar 7, 2008 | 08:45 AM
SoonerFan's Avatar
Cletus
Originally Posted by spdfreak
Unless your turbo.
which 99% of the people on here arent....
Old Mar 7, 2008 | 09:39 AM
AceofSpds's Avatar
wat
Get rid of pre-cats via headers/ypipe, keep factory cat. Plenty of info about this topic already.
Old Mar 7, 2008 | 11:39 AM
NmexMAX's Avatar
dot dot dot ...
The OP has a Cali spec, so this doesn’t even apply.
Old Mar 20, 2008 | 10:02 AM
MaxdFactor's Avatar
I just gutted/hollowed my cat, i'm in Fla.(no emissions testing here). Used a sim, no code probs... and great results. More throttle response/hp, works great with my magna flow exhaust and ram air intake.
Old Mar 20, 2008 | 12:04 PM
MintVQ35's Avatar
Dyno & timeslips to prove the "hp gains" ?!
JRod28
Dec 29, 2023 09:56 PM
Cotozic
Jun 28, 2017 08:01 PM
vanebecker
Aug 23, 2015 07:40 PM
maxinout93
Aug 20, 2015 02:17 AM
1992maximase30
Aug 5, 2015 09:27 PM
