Bose Woofer Cut Off Fix For 2000 Maxima
Old Mar 3, 2009 | 09:02 AM
  #41
Lontar1's Avatar
Puerto Rico-Maxima Lover
Originally Posted by Teddie18
The 2001 woofer set up is different than the 2000. That is why the fix is for 2000 Maximas, hence the title of the thread.
Does anyone knows how to fix this on an 2001
Old Mar 3, 2009 | 10:14 PM
  #42
AutoMaxic's Avatar
Alright so here's what I did--Im really hoping Im not totally f**ked. I cut the three wires going into the circuit board and I cut the 3 wires coming out of the circuit board. I then matched up the incoming and outcoming wire colors and tied them together. Is that what I was supposed to do? This didnt work at all for me.
Old Mar 4, 2009 | 08:16 AM
  #43
bigpopaj369's Avatar
the best sollution that i found is to completely remove the circuit board all together just cut the zip tie holding the plug and u will see were the boards connected just unlplug all the connectors and re connect the ones that are left leaving the board out. i did this and it does give u a pop noise on start up and u do get some of the other hi/low noises but there not really that noticeable.
Old Mar 4, 2009 | 12:57 PM
  #44
ReauDog's Avatar
Thats what i'm waiting on...
We need a solution for this problem for a 01!
Old Mar 4, 2009 | 09:17 PM
  #45
Teddie18's Avatar
Somebody started a thread for 01's a couple of months ago. I'm not sure if it resolves the problem or not.
Old Mar 5, 2009 | 05:54 PM
  #46
AutoMaxic's Avatar
Alright, well Ive pretty much given up on fixing this thing because it's still not working. However, now that Ive snipped the wires going into and out of the circuit board(and possibly screwed up the circuit board previously by attempting to solder the joints) eliminating the whole board, how screwed am I if I want to get an aftermarket speaker/woofer? The original plug coming into the trunk I have not touched. Also, anyone know of a decent price to replace that rear woofer with something else? I was told that I would need a new amp as well since it wont be bose. I really am not looking for anything really expensive, just something that sounds atleast equivalent to the original bose woofer.
Old Mar 12, 2009 | 02:28 PM
  #47
I30 GaTTo's Avatar
Great writeup Teddie18! You can't imagine how helpful that is to me. I have had this problem for quite some time, and have had no luck trying to get it fixed via Nissan or other stereo places. Thanks again!
I have just have one quick question. If I were to bypass the circuitboard, aside from the pop noise on startup, what kind of hi/low noises would the sub produce? Is it like a constant hissing sound, or is it something different? Thanks.
Old Mar 13, 2009 | 03:43 PM
  #48
BigDSheriff's Avatar
Subwoofer Fixed
Thanks for the great advice. I had the exact same problem with my 2000 Max. I took the board out, resoldered it, and I am back in business again. Appreciate the great tip!
Old Mar 13, 2009 | 08:19 PM
  #49
Child_uv_KoRn's Avatar
Bad *** Newb
Bose has bass?!?!?!? I just cut the wires and hooked it up to two 12s lol.
Old Mar 14, 2009 | 03:45 PM
  #50
I30 GaTTo's Avatar
Just wanted to say that I just took it out earlier today and soldered all five spots. So far so good. Thanks again Teddie18!
Old Mar 21, 2009 | 02:00 PM
  #51
Davidpcvsamoa's Avatar
My sub has been broken for over 2 years and I was thrilled to see a proposed fix. I soldered the five spots and it did the trick. Its working beautifully! Thank you Teddie18! Brilliant diagnosis and fix.
Old May 1, 2009 | 08:02 PM
  #52
Vaidz's Avatar
Thanks Teddie18. Your repair is applicable to the '01 with a few minor changes. I have posted the steps on the Bose Woofer Cut Off Problem for 2001 Maxima thread. Hope it works for others as well.
Old May 25, 2009 | 07:54 PM
  #53
tnt_legend's Avatar
thanks for the post bro. when I took off the chip i could shake the relay and the pins would move so it was an obvious connection problem... a lil solder and voila.... got that bass back.... (chip only on the 2000 maxima's i think)
Old May 26, 2009 | 12:41 AM
  #54
perkman87's Avatar
Originally Posted by PadawanKnight
It's possible to completely remove the "circuit board". As far as I understand it (my stereo knowledge is limited) that board is used to cutoff higher frequencies being sent to the sub. If you completely bypass it, the sub should work, but all frequencies will be sent. It's a double-edged sword since you'll get some noise you're not used to, but also here some of the lows that weren't low enough to make it through the filter.
I did that and it works fine.
Old Jun 9, 2009 | 08:28 AM
  #55
celticsbig3's Avatar
For those of you who decide to completely bypass the chip... you can buy a high pass filter at radioshack for under $10
Old Jul 14, 2009 | 07:46 AM
  #56
phatboislim's Avatar
u have a pic of the high pass filter?
Old Jul 22, 2009 | 10:00 PM
  #57
Old Aug 3, 2009 | 04:43 PM
  #58
Greg B's Avatar
Worked like a charm. Thanks for the info!
Old Aug 14, 2009 | 05:20 AM
  #59
nothing on the bypass filter huh?
Old Sep 1, 2009 | 11:17 AM
  #60
ez2000max's Avatar
Im a newbie here!! Just found the website. Usefull so far but, I have bypassed the circuit board now, but still nothing. Could it be the speaker itself?? I kind of ruled out the amp b/c when unpugged, no speakers at all work. IS THERE A fuse in the bose amp??
Old Oct 11, 2009 | 10:56 AM
  #61
spectrex42's Avatar
2003 Bose Woofer Cut Out Fix
I have just fixed the Woofer Cutout on a 2003 SE w/ Bose without bypassing the circut board.
Tools Needed
10mm ratchet with extension.
T15 Torx Bit
Small Phillips Screwdriver
Electronics Cleaner (Found at Radio Shack)
Arctic Silver Thermal Compound (Found at Radio Shack)
The issue for me lied in the amp located in the back corner of the trunk.
Using the 10mm remove the amp from the chasis and unplug the connector cable. (NOTE: Don't be alarmed if your speakers don't work at all whild this AMP is out)
Next remove all 8 Torx screws from the amp and remove the bottom casing. then remove the 2 phillips head screws that are all that is left in holding in the circut board. As you remove it you will see that there are two panels that touch the case that are covered in a pink putty. If it looked anything like mine that putty is everywhere. Use the electronics cleaner to clean the contacts and circut board if any putty got on it. Then put arctic silver on the contact points. DO NOT let the compound touch the circut board just put one stripe down the middle of the contact point.
Finally put the circut board back in and replace all screws and plug back in. That part of the amp will no longer over head and the signal should be good.
NOTE: I am in no way responsible for any damage you may cause to your car or stereo system. This a very simple procedure to do, took me about 30 minutes. Also this will void your bose warranty if you still have one.
Old Oct 18, 2009 | 11:25 PM
  #62
AEstylin's Avatar
Thanx guys for all the posts... big help
Old Oct 26, 2009 | 02:51 PM
  #63
acgrunt19's Avatar
I have an 03 with this same problem.....does any know deffinetly that this will fix the problem???
I searched and found that the HU might be the problem but id rather work on the rear deck first rather than the HU
Old Oct 26, 2009 | 07:01 PM
  #64
Teddie18's Avatar
Well, two posts up the guy says he has the fix. i don't know if it works but he says it does.
Old Oct 27, 2009 | 11:08 AM
  #65
bigpimpen092's Avatar
I still need to try this
Old Oct 27, 2009 | 04:44 PM
  #66
anyone?
Old Oct 27, 2009 | 07:57 PM
  #67
Superduck's Avatar
This fix worked for me. Pretty easy job too, except for climbing up in my trunk to detach things. Anyway, thanks to the original poster, you rock.
Old Dec 12, 2009 | 01:31 PM
  #68
arman's Avatar
i cant seem to unplug the wires, its really hard and its just not working for me.
is there anything im doing wrong?
ive been underneath that sub for a good 30 minutes and i cant get it off
Old Dec 12, 2009 | 03:04 PM
  #69
spock's Avatar
anyone?
It's actually a low pass filter. You need the speaker's parameters in order to calculate the values of the components required, (capacitors,resistors and inductors).
Old Jan 8, 2010 | 04:07 PM
  #70
sounds super complicated...i figured it was just a universal piece...
Old Jan 8, 2010 | 04:15 PM
  #71
chrys9989's Avatar
This worked great for me thanks.
Old Jan 12, 2010 | 11:55 AM
  #72
jashthedon's Avatar
Thanks a ton! 5 minutes job!Works perfectly!
Old Feb 11, 2010 | 09:58 AM
  #73
acgrunt19's Avatar
I have an 03 with the sub cutout....Does anyone know if this will work on the 5.5 generation??
I found people taking out there stock HU to solve this problem i would rather not have to do that... this sounds alot easier.
Has anyone done this on the 5.5 generation??
thanks guys
Old Feb 11, 2010 | 10:10 AM
  #74
Nelsito65's Avatar
thanks guys
See post #61 on this very same page.
Old Feb 11, 2010 | 01:30 PM
  #75
ghostrider17's Avatar
thanks guys
I may give this a go.
It's certainly less complicated than the 5.0gen fix.
Tried that a few yrs ago, and what a PITA...no workie either.
This seems easy and str8-fwd -- aside from the raping i;ll get @ radioshack.
Might try to source this goo elsewhere?
If I get'r fixed, I'll let you know.
Sick of my "phantom" sub -- but too cheap to replace it.
gr
Old Feb 11, 2010 | 02:28 PM
  #76
i8nda1's Avatar
my left side front and rear bose speakers cut out just when using the cd player what is the problem with them
Old Feb 11, 2010 | 02:58 PM
  #77
Are those speakers SUBS??
Old Feb 13, 2010 | 08:22 PM
  #78
i8nda1's Avatar
idk if there subs what ever come stock on the 03se TE bose system i would say there mids but what ever they r they **** me off when it happens. any idea what is happing?
Old Mar 6, 2010 | 03:31 PM
  #79
bigrza's Avatar
i dont think u wanna bypass da cb i think its a crossover filtering out da highs. imma try da soldering advice thanx
Old Apr 1, 2010 | 08:51 AM
  #80
Sylcurt's Avatar
Wow, did some searches and found this thread...can't wait to give it a try....I haven't actually tried this yet, so don't jump on me for asking...but is the grille on the parcel shelf difficult to remove?
the other question I had was I have been contemplating just adding an amp and an aftermarket sub....where would the best place be to "bite in" to the factory system to get the signal....? I searched and saw the schematics for wiring codes coming out of back of deck, but are these low level (like RCA) or speaker level? The Aamp I have is an older Mono block Alpine that can accept speaker level, so could I take the signal right off the + and - that go into the sub?
Going back to the problem with the OEM sub not working, could the problem be further up the line, in which there is no signal getting to the sub?...thus my idea of taking the leads from those wires wouldn't work, because they had no signal? sorry for the confusion created...
the system is not great compared to aftermarket installs I have done in my other cars, but my daughter mostly drives the Maxima, and I will be hooking up a USA SPEC NI15 cable this weekend to the Bose deck for her Ipod...she is content with the Bose OEM system, although having a bit of bottom end via the factory sub will be nice...if it doesn't work, then I 'll try to wire up the aftermarket amp and aftermarket sub in a box I have not being used.
