For those of you who use ramps..
Old Mar 11, 2008 | 04:14 PM
BCoon's Avatar
Any suggestions to a good set? I tried to use some my father had, but my bumper would make contact before my tires..
Old Mar 11, 2008 | 04:54 PM
BCoon's Avatar
Found some, and thought I'd share since these were much less than I expected..
If you want to buy from the store - Rhino Ramps seemed to be a good choice. Only about $35. Just google it, they're all over.
Since I'm already DIYing, I think I'll go this route: http://www.mustangworld.com/ourpics/...amps/index.htm
Old Mar 11, 2008 | 05:45 PM
Professor's Avatar
They sell them at Advance Auto Parts cheap.
Old Mar 11, 2008 | 05:48 PM
SoonerFan's Avatar
Cletus
if your car is lower, you need low profile ramps. i really have the problem with my mach 1 lip...i just use a jack and jack stands.
Old Mar 11, 2008 | 05:59 PM
NewfoundlandDud's Avatar
If you want to use your "fathers ramps", just put a small piece of 2x4 at the base of the ramp. When you drive onto the 2x4, your car will be higher, eliminating the sudden step. If this doesn't work, do a 1-2 2x4 stack similar to the DIY picture above. I had to do this while using ramps this summer.....
Old Mar 11, 2008 | 07:26 PM
BCoon's Avatar
Thanks for the tip; I'll try this tomorrow!
Old Mar 11, 2008 | 07:30 PM
BCoon's Avatar
Not sure if this is what you meant, but my car is stock height. These are some old school ramps - not sure if that has anything to do with how steep they are.
Old Mar 12, 2008 | 08:13 AM
stocked out max's Avatar
lots of clearance with a stock set up, and also works well if you have a stillen front lip
Old Mar 12, 2008 | 09:45 AM
hybridioN's Avatar
all teh single ladiez
my dad has these ramps that look like giant legos and he uses them to balance our camper. since i plan on going lower, these seem like a good choice, instead of getting an expensive low profile jack....for now atleast.
edit: http://www.rvpartscenter.com/Product...ID=160&CID=576
something like that, now that i think about it, it would take a lot to make a decent ramp. though, the concept is there...i guess.
Old Mar 13, 2008 | 09:25 AM
DAP's Avatar
DAP
I made my own like the guy in the Mustang forum. I just have 3 layers of wood instead of the 4 he has. If you drive through a new contruction neighborhood you probably could find all your materials in a dumpster.
Old Mar 13, 2008 | 11:27 AM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/forumdispla...sprune=-1&f=76
