Left side of Gauges are not lit
Old Mar 7, 2008 | 09:20 AM
CraigsMax01's Avatar
is there a how to on here to remove the gauge cluster, and replace bulbs?
i did a search, if its here i must have missed it?
Old Mar 7, 2008 | 03:34 PM
wyche89's Avatar
does it come on sometimes and go off sometimes, or always off?
Old Mar 7, 2008 | 04:02 PM
pmohr's Avatar
No more Maximas...
Seriously?
http://www.innerbean.com/housecor/chrome_rings.html
http://forums.maxima.org/showthread.php?t=211226
http://forums.maxima.org/showthread.php?t=199525
http://forums.maxima.org/showthread.php?t=147114
Old Mar 10, 2008 | 06:56 AM
'02_EMILBUS's Avatar
I've got a similar problem that the left side dash lights sometimes dont turn on when i start the car. Sometimes they come on very soon after, but there have been incidents where I've driven 10 minutes or so til they come on.
Old Mar 10, 2008 | 08:27 AM
01GLEMist's Avatar
mine go in and out, what is does that mean?
Old Mar 10, 2008 | 03:09 PM
wyche89's Avatar
well, i had the same problem with my 01 when i had an HID kit and LEDs installed in my sidemarkers.. after i took both out and turned the lighting back to stock, the problem went away.. i suspect it was the HID kit.. do you have 1?
Old Mar 10, 2008 | 03:10 PM
wyche89's Avatar
do you have an HID kit or LEDs? try returning your lighting back to stock.. the problem will probably go away
Old Mar 10, 2008 | 08:23 PM
01GLEMist's Avatar
all stock here
Old Mar 11, 2008 | 09:21 AM
Stock HIDs i posted about this once and believe that someone had the same problem and took the bulbs out and put them back in as if they were possibly not seated properly and just had a bad connection. This seems possible because it only happens sometimes.. seems to be in the cold more often, i believe.
Old Mar 13, 2008 | 11:02 AM
my issue is in the dash gauges, not the head lights. thanks for the info and yes i searched, this site isnt the easiest to navigate
Old Mar 13, 2008 | 11:05 AM
it was off for a day, then it came back
Old Mar 13, 2008 | 11:43 AM
im w/ ya on the dash gauges Craig! It happened to me a couple times last night upon startup but then start working after driving a little
RinconI30
Nov 10, 2015 10:55 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
minsbang
Sep 11, 2015 08:48 PM
asianstyle
Sep 10, 2015 11:30 AM
Maxima30
Sep 7, 2015 06:13 PM
