Proper Bedding in Procedure For Porterfields
Old Oct 30, 2001 | 06:17 AM
Moe's Avatar
Moe
I recently received my new pads. I was told that once they were in to make a couple of slow to moderate speed stops to avoid thermal shock to the rotors, then to make some hard/high speed stops and that was it. Is this correct or is there anything anyone would like to add?
Old Oct 30, 2001 | 07:15 AM
Jeff K's Avatar
Re: Proper Bedding in Procedure For Porterfields
You have the procedure...I usually do 60-0 stops, about three of them because then the brakes feel like mush. Make sure that you ride around for at least 2-3 miles without touching the brakes so they cool properly. I would also recommend that you change the brake fluid because changes are you just boiled it bedding the brakes.
Good choice on pads, those R4S pads kept me out of a few accident in the past.
Old Oct 30, 2001 | 08:06 AM
Moe's Avatar
Moe
damnit, thanks for the help. I was thinking about changing/flushing anyways.
Old Oct 30, 2001 | 12:58 PM
theMax's Avatar
should help bleeding
these help especially if you do work by your self.
speed bleeders
Apr 16, 2020 05:15 AM
James92SE
Oct 8, 2015 04:57 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Noela
Sep 26, 2015 08:22 AM
carid
Sep 17, 2015 05:00 AM
