Tranny flaring from 1st to 2nd
Old Mar 24, 2008 | 03:34 PM
hotstartup's Avatar
off late my tranny has a little flare going from 1st to second only on WOT. when it goes into 2nd gear, the rpm will be at about 4200 then go down to 4000 before going up again to 6k+ (happens for very short time the drop in rpm) car has 75k miles, any ideas? all service done on time.
how do we reset the ecu btw? in case that helps
Old Mar 25, 2008 | 05:29 PM
bwinter7's Avatar
Hey man, it seems like you're driving a manual tranny, correct? All that means is that your clutch is nearing the end of its life. The clutch can't hold the power of the 1 - 2 shift, so it slips a little bit.
Eventually, it will get a little worse, than worse, until even when you are at a light, and start off nice and easy, the clutch will slip. It's ok man, everyone has to do it at some point or another!!
-Brian
EIDT: Never mind, since you said "when it goes into second gear" I guess that means you're an auto. That might mean a rebuild of at least the torque thingy thats comperable to a clutch (I forget what its called) in a manual.
Old Mar 25, 2008 | 05:45 PM
hotstartup's Avatar
i filled the gas tank up and its fine.. wierddd. it was pretty low on gas but i doubt its related. seems to be fixed for now so we'll leave it.
Old Mar 25, 2008 | 05:55 PM
pmohr's Avatar
No more Maximas...
-Brian
Torque converter, and if you see his sig he's a GLE; only available as an automatic (factory).
Old Mar 25, 2008 | 05:57 PM
SoonerFan's Avatar
Cletus
1. this has been a known problem since(TCM) the 5th gen came out
2. nissan released a TSB
3. search to find out (TCM) the problem
4. dont listen to the other that have posted...(TCM)trust me. i had the problem with my 00 and researched it extensively
Old Mar 25, 2008 | 06:40 PM
Teddie18's Avatar
If you're driving a stick ignore this message. It wasn't clear whether you had an automatic or a stick but there is a technical service bulletin for a 1,2 and 2,3 shift delay for automatics.
I got pulled away from my computer after I started this message and saw that soonerfan beat me to the punch but he's right on the money. I had my car fixed under warranty for this well known concern.
Old Mar 25, 2008 | 06:41 PM
SoonerFan's Avatar
Cletus
if an MT has a delay between shifts, thats the drivers fault
Old Mar 25, 2008 | 06:59 PM
gotendbz1's Avatar
isn't the rpm suppose to drop after the car shifts then goes back up? if so what is the problem. The way you explained it, it seems liek it is normal.
Old Mar 26, 2008 | 12:09 AM
hotstartup's Avatar
i searched a few threads before i posted this and from what i found it seemed like the TCM issue was mostly happening in normal driving not at WOT. mine is an auto.
nissan shuld do a recall on the TCM!! there were so many threads on it.
Since the problem is not happening anymore should i leave it? or still go about replacing the tcm? any sure shot way of knowing if this is the problem? thanks guys
edit: searched up the TSB on this came up with the following link but its dead:
http://www.punkdork.net/max/tsb039a.pdf
Old Mar 26, 2008 | 07:37 AM
Teddie18's Avatar
If a manual is slipping or delaying engagement it could be:
  1. A worn pressure plate
  2. A worn clutch plate
  3. Bad slave cylinder
  4. Bad throw out bearing
  5. Leaking engine rear main seal
  6. Etc.
Old Mar 26, 2008 | 03:37 PM
foodmanry's Avatar
Da Roller Coaster!
TCM
Old Mar 26, 2008 | 05:58 PM
SoonerFan's Avatar
Cletus
Originally Posted by foodmanry
TCM
i already said that it might have been to subtle
Old Mar 26, 2008 | 07:44 PM
foodmanry's Avatar
Da Roller Coaster!
You used too many words...keep it simple stupid.
Old Mar 26, 2008 | 08:16 PM
SoonerFan's Avatar
Cletus
i was simply trying to be subtle...as apposed to blatant spoon feeding...
Old Mar 27, 2008 | 08:45 AM
NmexMAX's Avatar
dot dot dot ...
Can't forget the A33B TSB on the VB.
Old Mar 27, 2008 | 03:15 PM
Scottwax's Avatar
That's Mr. Detail to you
Saw a mention of that in the service manual for my car. If the TCM or soleniods don't fix a shift problem and the ATF is red and unburnt, next step is to replace the VB.
Old Apr 3, 2008 | 02:37 PM
punjabi's Avatar
I'm having the same problem but from 2-3. I searched on the org for hrs and as soonerfan mentioned and scottwax mentioned start from tcm.
James92SE
142
Jan 2, 2024 09:23 AM
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
