blower motor sound?
Old Mar 27, 2008 | 04:33 PM
albundy's Avatar
blower motor sound?
blower by passenger side making a weird "wirrrrring" sound? Just wondering if it is a part that maybe goes bad and if anyone else has experienced this? Thanks in advance
Old Mar 27, 2008 | 04:49 PM
SgtSchulze's Avatar
Burn Dust. Eat my rubber.
I've had the sound. If you take the motor cover off behind/underneath the glove box, you will find a piece of foam. I think that foam is used to deaden the sound from the motor. I stuffed the foam back in there and it quieted down.
Old Mar 27, 2008 | 06:28 PM
SoonerFan's Avatar
Cletus
common problem...with a TSB...look at TSB sticky
Old Mar 27, 2008 | 06:38 PM
jasonmax's Avatar
it's common. even with new blower motor, you still can hear the noise.
Old Mar 27, 2008 | 06:49 PM
albundy's Avatar
could not find tsb for this problem?
Old Mar 27, 2008 | 07:20 PM
jasonmax's Avatar
it also can be something stucking in the fan. just take the blowemotor out and clean it. don't disconnect the yellow connecter on the glovebox, otherwise you will get a airbag warning light.
Old Mar 27, 2008 | 07:47 PM
albundy's Avatar
do i have to remove the glovebox to get to the motor?
Old Mar 27, 2008 | 08:29 PM
SoonerFan's Avatar
Cletus
http://maxima.theowensfamily.com/tsb/NTB99-071b.pdf
Old Mar 27, 2008 | 09:02 PM
albundy's Avatar
thanks..im gonna take a look tommorrow
Old Mar 28, 2008 | 11:30 AM
albundy's Avatar
well it had crap in there and cleaned it out but still making the noise, so i guess next step would be to get the blower motor cover that nissan sells, which is supposed to deaden the sound?? goes for like 10.00 so i guess worth a try
Old Mar 28, 2008 | 03:58 PM
jasonmax's Avatar
if it's really making a lot of noise, it's time to get a new one. mine died at 67000miles.
btw: don't try to lubricate that blower motor, things can get worse.
Old Mar 28, 2008 | 04:46 PM
Reket's Avatar
What is the blower motor anyways?
Old Mar 28, 2008 | 04:52 PM
SoonerFan's Avatar
Cletus
AC/heater
Old Mar 28, 2008 | 05:11 PM
TheBigDu's Avatar
The bearing in my blower motor went bad at about 70k. The motor still worked fine, but the increased resistance burned out the fan speed control. On a manual climate control, this just meant that I could only use the blower at full speed (4). I replaced the resistor for $40 and bought an off-brand blower motor for $150, give or take. (I didn't want to replace the resistor again by leaving the original fan with the bad bearing in the car.) The non-OEM motor blower fit fine, but it was even louder than the stock one. I actually had a hard time hearing people and music over it when turned up to max 'blow'.
Old Mar 28, 2008 | 06:03 PM
nlmaxima's Avatar
An aftermarket blower motor for a 4th gen Maxima or a 96-04 Pathfinder will work on the 5th gen. Do a search it is proven. Lifetime warranty and only $62 shipped. here is a link http://cgi.ebay.ca/ws/eBayISAPI.dll?...MEWA:IT&ih=012
Old Mar 29, 2008 | 06:48 AM
albundy's Avatar
I did notice that on the TSB so i will deffinitely save that link, i am picking up the cover that nissan sells ( 10.00) and if that doesnt work I am going to go with that option. funny thing was when i had it out to clean it i hooked it up and turned the fan on and it seemed quiet, but the cavity that it fits in seems like a echo chamber...and also i didnt really notice this problem til i had my radio off, so thats the cheapest fix
Old Mar 29, 2008 | 08:28 AM
nlmaxima's Avatar
My blower motor has excessive end play the cage can move up and down. I got the most noise when it was cold, a few degrees below freezing. The noise I had was real loud like a growling sound.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Need help
23
Oct 2, 2015 08:56 AM
