Installed K&N 2KSE, now noticeable miss?
Old Apr 7, 2008 | 08:09 AM
vinco's Avatar
I started having a new phenomenon with my 2KSE 5MT (Fed.) car on the way to work this morning. To begin with, my CEL has been on since day one of ownership, with a P0430 (or 420 - I don't remember which) Cat Below Optimum Range code and an O2 sensor code, but no driveability problems up until this morning.
Then, this morning, it started with the CEL flashing - it seems like it was mostly when I was trying to accelerate in 4th and 5th gear. It flashed 4 or 5 different times, a different number of flashes each time - mostly 7 blinks. By the time I got 35 more miles toward work, it was noticeably missing. Maybe it was missing on the interstate, but I really couldn't feel it until I got off onto city streets, driving in traffic.
The only thing I've done is I put a brand new K&N drop-in filter (not a CAI) in it about 1K miles ago, and I changed the oil to Castrol Syntec Blend about 450 miles ago.
So the questions: Might the brand new K&N cause MAFS fouling problems as might be caused by a newly re-oiled filter? And might a fouled MAFS produce the flashing CEL and the driveability issue as described? I know the O2 sensor needs attention, but if I can just get it back to driveable first, that would be good.
Old Apr 7, 2008 | 10:03 AM
choiiiiiiiiiii's Avatar
unless the brand new filter was over oiled.....which wouldn't happen. when i dropped mine in i had no issues. if your maf is bad, then the car wouldn't be starting or would not be revving past 1-3k rpms
Old Apr 7, 2008 | 02:24 PM
Scottwax's Avatar
That's Mr. Detail to you
Check the codes. Probably have a new one that you are unaware of because you haven't corrected the original problem.
Old Apr 7, 2008 | 04:03 PM
NisTech's Avatar
flashing MIL light means multiple or cylinder # missfire code.. Most likely coils!
Old Apr 7, 2008 | 04:27 PM
hotstartup's Avatar
i have a k&n filter too, but took it out and went back to stock after reading all about the MAF issues, not worth the hastle! doesnt like your problem is filter related though.
Old Apr 7, 2008 | 04:54 PM
vinco's Avatar
So, can coils be tested individually, or do you just have to hit and miss and swap around coils for a diagnosis?
Old Apr 7, 2008 | 06:24 PM
00MaximaGXE's Avatar
go to autozone and have the codes read they told me what cylinders was misfiring.. did the tcs slip and ses code light up at once?
Old Apr 7, 2008 | 07:04 PM
hotstartup's Avatar
swapping coils will be a little bit of a pain for the back cylinders
Old Apr 8, 2008 | 01:59 PM
vinco's Avatar
Fixed!!!
I had Auto Zone scan the codes, and it showed misfire on #4. Since it was on the front bank and I had some tools, I changed the coilpack on the spot (although I tried changing the spark plug first.) Smooth like butta. I'm just glad it wasn't one of the rear bank coilpacks. I probably need to just go ahead and change them now, so I don't get stranded somewhere away from home.
Old Apr 8, 2008 | 02:33 PM
kramarz99
good job NisTech....
Old Apr 8, 2008 | 02:37 PM
vinco's Avatar
Thanks all!
JRod28
Dec 29, 2023 09:56 PM
Finkle
Sep 27, 2015 09:53 PM
jerrod99_se-l
Aug 24, 2015 10:24 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
vanebecker
Aug 19, 2015 09:45 AM
