HELP.....CAR STALLING OUT AND IDLEING LOW
Old Apr 12, 2008 | 08:24 AM
mynesbts's Avatar
Sup guys i have a 2001 maxima ae edition 5SPD.I changed the IACV and the ECM Car starts up and runs fine for like a hour.Then the idle starts to drop a little to 600 rpm.a few minutes later the idle will drop below 500rpm to 0rpm and jump back up Almost cutting off.Then finally will cut off after a couple stop signs or lights.If i try to start it from the on position it will start but stall right away.But if i turn the key all the way to the off position then turn it on it starts up fine.But 10 minutes later it will start acting up again....I have no service engine lights and no codes came up in the history.My mechanic cant figure it out he even adjusted the idle and still the same problem.Any one have a idea???Im thinkin its the MAF
Old Apr 12, 2008 | 08:50 AM
P. Samson's Avatar
Did your mechanic accomplish the Idle Air Volume Learning procedure? It doesn't sound like he did.
Old Apr 12, 2008 | 10:28 AM
AEMAXIMA01's Avatar
I can almost guarantee you its your MAF. I have an AE 5spd, and I went through the exact situation about a month ago. Coming up to stop lights I would put it in neutral and let it coast, then RPMs would drop, and eventually it died. Mine never threw any codes either. It even did this to me in the middle of a turn, ie I lost power steering until I could get it restarted. I did some research on here and thought that it was the IACV, but instead it was the MAF. I ordered one from Dave B and voilia! Fixed!
Old Apr 12, 2008 | 06:59 PM
mynesbts's Avatar
im gonna change the maf ill keep you guys posted
Old Apr 12, 2008 | 09:28 PM
mynesbts's Avatar
btw anyone have the number to daveB?
Old Apr 13, 2008 | 06:28 PM
latino73's Avatar
daveb@adpub.com
David Burnette
(512)444-1400
Old Apr 20, 2008 | 11:25 PM
mynesbts's Avatar
well put the new maf and the problem is still there....any other suggestions people?
Old Apr 21, 2008 | 01:15 AM
theoverachiever's Avatar
Id say vacuum leak.
Old Apr 21, 2008 | 10:30 AM
NmexMAX's Avatar
dot dot dot ...
Seems like a problem that should set off an SES. Do you have an SES, and if so, do you have the code to go along with it?
Old Apr 21, 2008 | 11:12 AM
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
Old Apr 21, 2008 | 11:16 AM
mooseq30's Avatar
sounds like a fuel related problem, I would hook up a volt meter to ur maf and see if it is droping hard before the car shuts off if it is than its the maf or some sort of vacuum leak like said previously! Check the vacuum levels and see if they are fluctuating? if not then check the spark plugs? other than that maybe compression check each cylinder!
Old Apr 21, 2008 | 11:39 AM
NmexMAX's Avatar
dot dot dot ...
on vacuum leak.
Old Apr 25, 2008 | 11:49 AM
mynesbts's Avatar
WELL THEY CHANGED THE IACV AGAIN AND THE PROBLEM STILL OCCURS THEY CANT FIGURE THIS **** OUT
Old Apr 25, 2008 | 01:00 PM
NmexMAX's Avatar
dot dot dot ...
Well, they changed the IACV once, so maybe that should have told them not to change it again, since, well, tat option seemed to be eliminated. Perhaps it is a vacuum leak, have they checked vacuum yet?
Old Apr 25, 2008 | 07:03 PM
foodmanry's Avatar
Da Roller Coaster!
Vacuum leak.....
Old Apr 25, 2008 | 08:50 PM
NmexMAX's Avatar
dot dot dot ...
I see a pattern here.
Old Apr 26, 2008 | 09:56 AM
foodmanry's Avatar
Da Roller Coaster!
Where? Hhmm....
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
