Dual tip Muffler
Old Apr 15, 2008 | 02:53 PM
Dynasty47x1's Avatar
Exhaust Build
Does anyone have a pic of the megan muffler or any other dualtip muffler of the inside looking through the tips or inlet or can someone describe to me what the inside of their Dual tip muffler looks like. Im starting my catback build and would like to see what the different layouts inside of dual tip mufflers are.
This will probably spread out between 2 or 3 months and then a sound clip if it sounds good.
Old Apr 15, 2008 | 03:17 PM
This is the muffler im going to start the build out with im still looking into which b pipe and resonator im going to use. This is a cheap mans build so it will be under 300 im a see how low i can go and have a decenct sounding catback that muffler is not going onto the car by it self.. 2.5 inlet 3in dual straight tips
Old Apr 15, 2008 | 03:26 PM
SuperStasiu's Avatar
muffler is way to small for the car i had one on for like two weeks threw it out. Its the one you get of ebay for like 40 bucks right?
3jays2max0's Avatar
what muffler is that?
Old Apr 15, 2008 | 03:33 PM
http://cgi.ebay.com/ebaymotors/NISSA...spagenameZWDVW
these things are tiny do not buy it its rice
Old Apr 15, 2008 | 05:38 PM
harmbone2k2's Avatar
6yrs old=36,500 miles :)
So...what exactly makes that muffler rice??? The sound, the welds, the tips size, the overall size? Just curious.
Old Apr 15, 2008 | 05:58 PM
DrunkieTheBear's Avatar
Turbo'd Saab
IBthisturnsintopuppettellingushehadit and nmexmaxtellsusthatstockisbetter.
Frankencar FTW
Old Apr 15, 2008 | 07:15 PM
Im just starting with that muffler if i dont like it ill try something else but i dont think it will sound to bad when im finished. Thats good that its not that big i dont want a big muffler its probably ricey when you just weld it on to the stock setup but im using it in a custom setup on a budget but i am going to take advantage of resonators if necessary.
Old Apr 15, 2008 | 07:37 PM
Why do you say its to small is that a personal preference its bigger than stock I just want a little sound and real tips and again just a test and if it sounds good when ive completed it other people on a budget can have a budget catback.
Old Apr 15, 2008 | 07:44 PM
Frankencar FTW
Dont have the Frankencar money ftw
Stock may be better just trying something new
If anything ill just take this muffler off and weld on the stock muffler to the setup and add the same tips
Old Apr 15, 2008 | 07:52 PM
13SEC350Z's Avatar
looks good
Old Apr 15, 2008 | 08:10 PM
Originally Posted by 13SEC350Z
looks good
Thanks I see you've been busy
Old Apr 15, 2008 | 11:15 PM
blkAEmax82's Avatar
Glory Glory Man United
Stock 5.5 muffler FTW !
Beat Nmexmax to it
Old Apr 15, 2008 | 11:35 PM
SoonerFan's Avatar
Cletus
stock muffler is fine...all you need to upgrade is the b-pipe
Old Apr 16, 2008 | 09:36 AM
Turbo'd Saab
Beat Nmexmax to it
but you didn't beat me
Old Apr 16, 2008 | 06:21 PM
5.5 muffler cost more if i dont like the sound ill have the stock welded on to the b pipe with similar tips
Old Apr 16, 2008 | 06:30 PM
G35 sedan stock muffler ftw
Old Apr 17, 2008 | 05:59 AM
97maximany's Avatar
Nice
Old Apr 17, 2008 | 06:16 AM
NmexMAX's Avatar
dot dot dot ...
Old Apr 17, 2008 | 06:20 AM
n3985's Avatar
大陆弟弟
I see tiny lil exhaust tips, am I missing something?
Old Apr 17, 2008 | 06:21 AM
NmexMAX's Avatar
dot dot dot ...
Stock FTW! No tips here.
Old May 13, 2008 | 11:53 AM
Ordered my Y-pipe and and catback parts pics when i receive the goods
Old May 13, 2008 | 08:13 PM
CMax03's Avatar
See ya gonna have to trim your rear valance in order to get your tips to clear the bumper opening! They're to far apart and to wide! Hopefully you were able to locate a 19" Muffler cause 14"er's are too small for the Maximas!
Personally, all you needed to do is buy some single round slant cut tips (2.5" 0r 3"), and cut the OEM tips back a little, then center the SS tips over the cut Oem on the muffler rear plate and tack weld them here and there! WaLa! I did this with Borla's 2.5" SS round slant cut to beef up the look a little! Without sacrificing the OEM trick muffler's quietness and power combo!!!
Old May 13, 2008 | 08:18 PM
maxspeed96CT's Avatar
The original VQ...
Srry guys but that dtm in the pic above it not at all ric cause its small. I think that would look perfect on a max...
Old May 13, 2008 | 08:33 PM
Scottwax's Avatar
That's Mr. Detail to you
Stock 5.5 gen muffler painted black with slightly larger than stock stainless steel tips ftw.
Old May 13, 2008 | 08:46 PM
Its between that and the stock muffler.Which ever sounds better im probably going to xat racing in tampa to have the work done. I don't want to big a muffler and that one is pretty close to stock size. The tips are the same amount of space apart as stock only thing might be the issue in the 3in diameter but then for megan and cattman mufflers the owners would need to trim their bumpers also but it doesn't seem like they have to and this muffler is smaller than both of those 14" verses 22" length i believe.
Old May 13, 2008 | 09:35 PM
CMax03's Avatar
I'm running a Cattman 00-03 Rear Muffler Assy and the Muffler body is exactly 19" in lenght, The tips are 3" diameter, Total diameter of both tips side by side are 6.25" and the tip centers are 3.25" apart! And none of the 00-03 Maximas had to trim our rear valance, just the 01 20 Anniversary Maxima and the I30/I35 family! That's why their exhaust tips curved downward, valance offered no openings! Also your tips are centered in muffler body height wise, where as the Megan and Cattman tip are closer to the bottom of the muffler body as is the OEM!
Old May 13, 2008 | 09:56 PM
I see what your saying I ll work it out or they'll work it out I could gut off those tips and weld them to the stock muffler. again im just starting off with that muffler. ill see how it turns out there will be pics in a couple .weeks
Old May 14, 2008 | 06:17 AM
phatboislim's Avatar
i always wondered what muffler was used to utilize those tips...
eye argh haa pee
Old May 15, 2008 | 10:09 AM
I ordered a warpspeed y-pipe a warpspeed highflow cat and the piping for the catback setup and im placing an order for the jwt cattman intake after everything is installed should i have the car tuned at the shop. Also what can I expect from the tune would it make a difference?
Old May 15, 2008 | 11:08 AM
For the intake should i get the cattman jwt combo for the 189 or just the jwt for 109? what are the benefits of each.
Old May 15, 2008 | 04:12 PM
Any suggestions?
Old May 16, 2008 | 04:07 PM
CMax03's Avatar
I'm not sure if Cattman even sells the "Cattman Combo" anymore! I tried getting one from about 3 yrs ago and he didn't have anymore! He does sell the JWT POP filter but I think it's cheaper @ Courtesy Nissan! Berk offers an Intake like the Cattman Combo for some extra $$$!
Old May 16, 2008 | 05:40 PM
Hes doing a group discount for may in the gpd section for may for 189 because hes going to start making them again. And at courtesy the jwt is 109 im trying to figure out which is worth it.
Old May 16, 2008 | 06:23 PM
Really well then the one i had of ebay for like a week on my car was tiny take pics of it next to the stock exhaust
Old May 17, 2008 | 06:45 PM
PlanoSER's Avatar
Hey, to the guys running headers w/ stock muffler.
I have cai, cattman headers, race cat, and stock catback. I like the quiet sound of it, but it sometimes has a 'buzzy' kind of sound.. Anybody else experiencing that? Up next for me is to get an aftermarket b-pipe , hope that maybe helps the way it sounds...
Old May 17, 2008 | 07:09 PM
blkAEmax82's Avatar
I got headers and a test pipe, gutted Bpipe, 5.5 muffler and i as well get that Buzzy (bees in a can sound) I hate it. My friends are telling me to pick up a Cattman Bpipe and put my Stock Cat back on .
Anybody got .02 on this??
Old May 19, 2008 | 07:06 AM
Originally Posted by scottwax
stock 5.5 gen muffler painted black with slightly larger than stock stainless steel tips ftw.
hey where did you get your tips from?
Sorry for the caps
Old May 19, 2008 | 07:55 AM
amomaxima's Avatar
cattman FTW
had the catback for 4 years now and on two cars
cant/wouldnt imagine driving without it
Old May 21, 2008 | 03:10 PM
Y-Pipe Arrived
Y-pipe is here catback parts are on back order have to wait.
