Completed!! Shock Sensor install on factory alarm! One day early!
Old Nov 1, 2001 | 06:38 PM
RussMaxManiac
Yes guys and gals, the install was successful. The car now has a shock sensor and it works great!!!! I will take a video of it actually working soon, but for now, the HOW-TO page is done with pictures and step-by-step how to install one for yourself!
Enjoy!
http://www.5thgenmaximas.com/shocksensor.html
P.S., this will work on 4th gens as well...just read the instructions.
Old Nov 1, 2001 | 06:49 PM
BigDogJonx's Avatar
Old Nov 1, 2001 | 08:48 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Congrats!
Old Nov 1, 2001 | 08:55 PM
Y2KMaxGXE-R's Avatar
that is so neat. Russ, how much $$ this cost you?
Old Nov 1, 2001 | 09:07 PM
TimW's Avatar
The silent but deadly Moderator
yeah...
my HID alarm fix didnt work tonite.. the last thing I want is my alarm going off
Old Nov 1, 2001 | 09:08 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Nice job RUSS!
Thanks, I've been wanting to do this for awhile, but never got around to it.
I have one tip/question. Instead of drilling a hole through the firewall to tap the HOOD switch, it would be easier to just tap ONE of the HOOD/DOOR/TRUNK wires coming from the SMART ECU right where you installed the shock sensor.
On a 2000:
Door Switches Wires: 28(Red/White), 29(Sky Blue), 40(Red/Light Blue)
Trunk Switch Wires: 38(Purple/Yellow)
Hood Switch Wires: 27(Yellow/Black) Same one you tapped.
On a 2001:
Door Switches Wires: 1(Sky Blue), 2(Red/Light Blue), 3(Red/White)
Trunk Switch Wires: 13(Purple Yellow)
Hood Switch Wires: 6(Yellow/Black)
I can write out MOST of the SMART ECUs' plug wire colors if your interested, so people can figure out which ones they need to tap.
Again THANKS for the good work!
Old Nov 1, 2001 | 09:49 PM
BigDogJonx's Avatar
Re: Nice job RUSS!
On a 2000:
On a 2001:
I was just going to hunt around in my SMART ECU to figure that out. But once again Alex beat me to it.
By the way, check your PM
Old Nov 1, 2001 | 09:55 PM
TimW's Avatar
yo dawg...
I wish your homeypage would load....
Old Nov 1, 2001 | 10:00 PM
BigDogJonx's Avatar
Re: yo dawg...
Yeah my PROVIDER is down. Whats the deal, how did your alarm fix not work? I thought you had it all figured out?
Old Nov 1, 2001 | 10:08 PM
TimW's Avatar
yeah...
me too... all I have is a bloody thumb, more scuffs on the top of my HID housing (removal/reinstall on driver side is hard!), a few missing hours, and STILL flashing HIDs to show for it
Old Nov 1, 2001 | 10:50 PM
BigDogJonx's Avatar
Re: yeah...
Stop being a girlie girl and just do my Alarm fix once my site comes back up.
Old Nov 2, 2001 | 05:48 AM
RussMaxManiac
Read the page again its all there.
$10
Old Nov 2, 2001 | 05:49 AM
RussMaxManiac
Re: Nice job RUSS!
Where is the smart ecu device at? I could not locate it. I might redo that one wire this weekend then.
On a 2000:
On a 2001:
Old Nov 2, 2001 | 07:50 AM
neil's Avatar
quick question regarding the shock sensor? i sthat universal? or + or - trigger? and can i pick that up locally?
by the way great job, well written !!!
neil
Old Nov 2, 2001 | 08:23 AM
HulaMAX's Avatar
WoooHoooo! Gotta add this one to the mods list!!!
Old Nov 2, 2001 | 09:13 AM
IceY2K1's Avatar
Re: Re: Nice job RUSS!
It's kinda hard to explain, but it's in plain sight.
Here's a PDF file(had to zip to attach it) of the location.
There are TWO plugs. The one closest to the driver is the lower numbers, hence 1,2,3... You can match the numbers with the pins by the wire colors.
If you need more, PM me.
Old Nov 2, 2001 | 09:59 AM
RussMaxManiac
neil
Universal, with negative trigger.
Old Nov 2, 2001 | 03:43 PM
DeaZaL's Avatar
awesome man
I have to say you always have the most through write ups. Very well done. I would like to get this done before winter.. Do you know what temperatures that shock sensor can operate at?? I don't realy want to drill a hold so I'll wait till you figure out exactly what wire to tap.. then i do ...
Old Nov 2, 2001 | 03:47 PM
DeaZaL's Avatar
Ohhh
Ohh Don't forget to change your page title, looks like you were using your Clear corner page to get started I always forget myself...
BTW-I think your site is awesome just needs some cosmetic work on the front page.. What have you been using to code? Straight code or a proggy.
lemme know.. i very busy but i may be able to help ya out a bit
Old Nov 2, 2001 | 09:49 PM
BigDogJonx's Avatar
Re: Re: Re: Nice job RUSS!
Ice you want to explain to him that since he gots a 2001, his SMART ECU is gonna have THREE plugs going into it and almost 90% of the pin#'s are not going to match.
Dixit
Old Nov 2, 2001 | 11:11 PM
RussMaxManiac
Re: Ohhh
I am busy too, FP2000 is what I use...
Old Nov 3, 2001 | 04:06 AM
DeaZaL's Avatar
k
Old Nov 3, 2001 | 01:00 PM
IceY2K1's Avatar
Re: Re: Re: Re: Nice job RUSS!
Dixit
What? I'm not sure what your saying?
I listed both. I have ALL the 2000 wire colors and ENOUGH of the 2K1-2K2 wire colors.
It's very simple to use a few wire colors as reference and know which pin is 1, 2, 3, etc...
Old Nov 3, 2001 | 03:21 PM
BigDogJonx's Avatar
Re: Re: Re: Re: Re: Nice job RUSS!
No No, I was just trying to say that the actual unit on the ESM shows that it has only TWO plugs for the 2K, but the 2K1 now has 3 total plug going into the unit.
Dixit
Old Nov 3, 2001 | 06:29 PM
AznWontonboy's Avatar
Re: yeah...
Tim, is it really a big deal? Because if Nissan made ie like that, then it should be ok... unless the 2k2s dont flash...
Re: yeah...
Tim, is it really a big deal? Because if Nissan made it like that, then it should be ok... unless the 2k2s dont flash...
Old May 2, 2003 | 01:38 PM
MacGyver's Avatar
any link for the directions? nothing is loading...
Old May 2, 2003 | 01:59 PM
Quicksilver's Avatar
OT n00bs FTMFCSL
Did you notice the date on the last post when you replied to it dude?
[maxi-overdose]'s Avatar
5thgenmaxima.com is not in service anymore
now Russ's write-up is on Kevin's site.
http://www.boostedmaximas.com/howto/
Old May 2, 2003 | 02:02 PM
IceY2K1's Avatar
Damn...another thing I've been meaning to do.
Where the heck does all the time go.
Old May 2, 2003 | 02:59 PM
2M0A0X2's Avatar
what!? i haven't been on here for a while.
Russ actually traded his CL!??
and I see that he has an Audi, but does he ALSO have a maxima again??
Old May 6, 2003 | 01:50 PM
MacGyver's Avatar
i didn't see that before...
Has anyone done this? does it work? if the sensor goes off, does it turn off after 30 seconds and re-arm or what?
Old May 6, 2003 | 01:55 PM
K Pazzo 6's Avatar
Start a new thread & ask....b/c Russ got so he cant answer your question...
vingodine
45
May 21, 2016 12:46 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Team STILLEN
Aug 10, 2015 04:29 PM
MikesChevelle
Aug 6, 2015 11:36 AM
