5th gen maf orientation?
Old May 5, 2008 | 07:12 AM
dfownz's Avatar
Does it matter if a 5th gen maf is rotated at all? I switched up my intake and mounted the maf so the FLOW -> is facing upwards. I went for a test drive and I get a p0100. Now the car runs kinda wierd, but will go all the way to redline.
Do you guys think having it rotated is screwing it up?
Old May 5, 2008 | 08:57 AM
AceofSpds's Avatar
wat
yep
Old May 5, 2008 | 09:26 AM
dfownz's Avatar
Have you actually verified this?
Old May 5, 2008 | 09:51 AM
SoonerFan's Avatar
Cletus
it was verified by your light coming on.....
Old May 5, 2008 | 10:24 AM
nismology's Avatar
I don't see why that would matter. Are you sure you didn't turn the key to the "ON" position with the MAF disconnected?
Old May 5, 2008 | 10:52 AM
jasonmax's Avatar
of couse it matters, the MAF should always againsts the flow of air, not the same direction...
Old May 5, 2008 | 11:07 AM
dfownz's Avatar
Nope, definetly didn't do it. I've already done it once
All I did was rotate it 90 degrees on the couplers, not switch it around or anything.
Old May 5, 2008 | 12:46 PM
Professor's Avatar
there is a arrow on it ----------> faces the throttle body.
Old May 5, 2008 | 01:03 PM
dfownz's Avatar
Yes, I know and have it set up properly. Again, I ROTATED IT IN THE COUPLERS not flipped it around.
Old May 5, 2008 | 03:45 PM
knight_yyz's Avatar
Toolie
it does matter which way it is rotated. The harness should be pointing up, unless you have tuned with a piggy back.
Old May 5, 2008 | 06:52 PM
dfownz's Avatar
Gracias!
Old May 5, 2008 | 06:58 PM
nsnrider's Avatar
can you post a pic of your intake? I wanna see what you did here.
Old May 5, 2008 | 07:23 PM
SoonerFan's Avatar
Cletus
you can rotate the coupling and it wont cause an issue
Old May 6, 2008 | 12:25 AM
AceofSpds's Avatar
wat
its been stated in a few other threads (not sure if it was here though)where people's maf's would act funny if it was on its "side"
Old May 6, 2008 | 08:37 AM
dfownz's Avatar
I would, but I had to put it back because the maf couldn't sit properly. I was doing something similar to greymax using the stock intake box. Now I just have a tb->3"->maf->cone filter nothing really special at all.
Old May 6, 2008 | 08:42 AM
SoonerFan's Avatar
Cletus
in my 00, i had my berk in such a way that the MAF was sideways.....
Old May 6, 2008 | 09:10 AM
NmexMAX's Avatar
dot dot dot ...
The clocking of the sensor has been said to affect AFR, but not to the point of affecting performance, which in your case seems quite drastic.
I might first guess would be that you have an intake leak somewhere in between the MAF and TB. A pic of your currents et-up would also help. Also, are you still using your PCV tube in between the MAF and TB?
Old May 6, 2008 | 01:25 PM
dfownz's Avatar
Nah, I only have one vacuum line before the throttle body and its for that stupid boost sensor.
Let me guess.....the pcv tube is crucial huh?
EDIT: Another thing, when I just let my car idle it will eventually die (like 50% of the time). I wish I had a picture, but its a very simple setup.
THROTTLE BODY-----Vacuum for boost sensor--------maf--------cone filter
It has a 45deg bend between the maf and tb and puts the cone right where the battery should be. I also did away with the "wedge"/silencer that was between the filter box and the tb.
Old May 6, 2008 | 01:28 PM
NmexMAX's Avatar
dot dot dot ...
The PCV tube, if not connected, causes a lean idle condition, which then turns into a 'rough' idle. It shouldn't affect WOT performance though. Try getting it back into the mix and see if it helps.
Old May 6, 2008 | 01:54 PM
dfownz's Avatar
Looks like its brass fitting time
MAXSE5SPD
Sep 17, 2022 04:00 AM
-ReLLiK-
Apr 29, 2016 06:25 PM
ballerchris510
Sep 10, 2015 09:35 PM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
