Car doesn't start!!
Old May 10, 2008 | 06:14 PM
hazardeyes's Avatar
Car doesn't start!!
Hello, I am having another problem with my Maxima, The car doesn't start, no crank at all, this past week, the car had some trouble starting very heavy crank , took several tries in order to get the car to start, now! it doesnt start at all, i dont hear any crank nada capout !!!! I started off by changing by myself the igniters, I then tried to start the car, same problem! No crank nothing !!! what is the problem, is it the starter ? because battery is brand new so we can rule that out directly !
Old May 10, 2008 | 06:26 PM
jasonmax's Avatar
have someone checked your battery if it has electricity. I think your alternator has gone so the battery drained out.
Old May 10, 2008 | 06:28 PM
hazardeyes's Avatar
I am not having problem with the battery, its brand new! all power in the car is perfect! , its not turning on, no ignition!
Old May 10, 2008 | 06:33 PM
jasonmax's Avatar
I know it's new, but it doesn't mean that it has power.
have someone given you a jump start then you will know if your battery is empty or not.
if the jump start can start your car, it means your battery is empty, check your alternator.
otherwise, check your starter.
Old May 10, 2008 | 06:41 PM
hazardeyes's Avatar
we tried jump starting! nothing at all i had the battery for 4 months now!, I will have myfriend check the alternator, otherwise you think its the starter ? Because this week the car has been giving me signs! had to crank for a long while in order to have the engine started! If its the starter, I can change it myself, if its the alternator which i hope its not, i had it changed 2 years ago by the way!
Old May 10, 2008 | 06:44 PM
jasonmax's Avatar
if a jump start won't start the car, check the starter and it's wires and fuses.
Old May 10, 2008 | 06:45 PM
AceofSpds's Avatar
wat
starter or grounds, check em and search on how to
Old May 11, 2008 | 07:44 AM
hazardeyes's Avatar
thanks!!
Old May 11, 2008 | 11:27 AM
sublime258's Avatar
Had the exact same problem recently...car started slowly for a few days then wouldn't start at all. Check your battery terminal connections, but it's most likely a dead starter.
Old May 11, 2008 | 01:56 PM
DrunkieTheBear's Avatar
Turbo'd Saab
Starter
Lakersallday24
Jun 16, 2019 01:35 AM
scutmud
Aug 28, 2015 05:04 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
BobMax
Aug 15, 2015 12:35 PM
