I want to replace my bearings what synthetic grease should be used?
Old May 11, 2008 | 01:34 PM
TopSpeedNY's Avatar
I have Timken front bearings want to replace with the axles whats the best synthetic grease should be used for them or sealer.
Regards,
Mike
Old May 11, 2008 | 04:22 PM
MacGarnicle's Avatar
Regards,
Mike
exactly where would you be using grease when replacing your bearings? From what i remember no grease was required on this job...
Old May 11, 2008 | 05:18 PM
nlmaxima's Avatar
Bearings should be sealed on each side and if they are not sealed I would not use them.
Old May 12, 2008 | 08:18 AM
TopSpeedNY's Avatar
Exact Picture of the bearing.
Old May 12, 2008 | 08:19 AM
TopSpeedNY's Avatar
Does this needs seal or grease and which one.
Thanks.
Old May 12, 2008 | 09:47 AM
nlmaxima's Avatar
No external seal needed the bearing is a sealed unit(no roller bearings exposed, sealed on each side). Do not remove a seal and try to add more grease.
Old May 12, 2008 | 10:32 AM
indeed - if you plan on opening the bearing, you better order two because that one will be useless.
Our bearings are pressed in. If you're trying to push the sucker in, a lack of grease isn't yoru solution.. a 2 tonne press is
Old May 13, 2008 | 08:23 PM
CMax03's Avatar
bearings, bearings and more bearings
Thanks.
Just press it in... correctly and call it the day! Or if you're not happy with those bearings, take the p/n and go buy a higher quality bearing from a local bearing supply that may by serviced with synthetic grease! How do you know these aren't filled with synthetic grease?
mvm062
Nov 30, 2020 09:00 AM
Starrider
Sep 17, 2015 07:26 AM
maximusrising
Sep 2, 2015 09:55 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
