Engine races at start up
Old Nov 2, 2001 | 01:00 PM
madmax2k1's Avatar
Does anyone knows why the Max engine races at start up, this happens when the engine is cold, it shoots up to 3-4K rpm than goes back to 1k rpm.
Old Nov 2, 2001 | 01:18 PM
UMD_MaxSE's Avatar
Got Bent?
It is normal.... I don't remember mine going up to like 4k rpm, but it does go up to between 2k and 3k rpm....
Old Nov 2, 2001 | 01:24 PM
NYC2SD's Avatar
As long as it settles down after a second or two then you're fine. Higher idle speeds at start up, helps get the Cats warm quicker.
Old Nov 2, 2001 | 01:25 PM
BigDogJonx's Avatar
Re: Engine races at start up
You sure it goes up to 4k? you sure you aint by accidently gas-ing it while you start the car?
Old Nov 2, 2001 | 01:31 PM
Jeff92se's Avatar
I'm needing a caw
Mine will do this too if the car has been sitting for more than a few days or if the morning is colder than usual.
Old Nov 2, 2001 | 02:38 PM
maxse01's Avatar
Mine only goes to about 2200 on start up. No matter what temp it is, but that's probably cause it sits in a heated garage
Old Nov 2, 2001 | 06:36 PM
adman's Avatar
Take it out of R...
R stands for Race!
ADMAN
Old Nov 2, 2001 | 11:35 PM
Menasor's Avatar
Well I heard that the reason that happens is because the EGR is open and it's recirculating exhaust back in so that the engine r cat heat up faster or something like that. In other words its normal to have it shoot up to 2500 or 2000 rpms cause mine does that too and after like a minute it goes to 1000rpms and below.
Old Nov 2, 2001 | 11:49 PM
AznWontonboy's Avatar
4000? is that a mistake?
Matt93SE
May 24, 2019 02:58 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Team STILLEN
Aug 10, 2015 04:29 PM
