I did my spark plugs and now I have a P1320
Old May 17, 2008 | 11:13 AM
pyroz's Avatar
I did not have this code before I changed my sparks. I know it mean it is a bad coil but are the coils that sensitive that after i did my sparks, they die? Is there a way to pinpoint which coil is bad to replace? Thank you very much.
Old May 17, 2008 | 01:12 PM
Scottwax's Avatar
That's Mr. Detail to you
Double check the connections. You may not have on pushed on the plug all the way or you tweaked a wire.
Old May 17, 2008 | 01:31 PM
pyroz's Avatar
I just did the test where I disconnect one plug at a time. all of them seems to be idling the same. I just checked the wires, nothing seems nipped or tweaked. Any other prognosis? Thanks for your help. Really hate to shell out $300 for it. It is a 2000 max btw.
Old May 17, 2008 | 01:33 PM
SoonerFan's Avatar
Cletus
still sounds like a connection problem to me
Old May 17, 2008 | 01:51 PM
pyroz's Avatar
Ok. So its not the coils? I will recheck the connectors. The engine is somehwat smooth when idling with all 6 plugged in but after i take one out, it'll start to idle roughly. the rough factor varies from coil to coil. but still noticeable.
Old May 17, 2008 | 04:39 PM
pyroz's Avatar
Ok. I took out every coil and I tested them with an multimeter. From 1-6 in this order:
1-3-5
2-4-6
Here are the readings. The reason for K Ohms and M Ohms, is because my multimeter only had the Auto Ohm option, I couldn't choose 20k Ohms to test.
+1, -2 : 1.427 k Ohms
+1, -3 : 8.19 m Ohms
-1, +2 : 1.423 k Ohms
-1, +3 : i
-2, +3 : i
+2, -3 : 8.52 m Ohms
+1, -2 : 1.540 k Ohms
+1, -3 : 7.12m Ohms
-1, +2 : 1.538 k Ohms
-1, +3 : i
-2, +3 : i
+2, -3 : 7.23 m Ohms
+1, -2 : 1.438 k Ohms
+1, -3 : 8.01 m Ohms
-1, +2 : 1.438 k Ohms
-1, +3 : i
-2, +3 : i
+2, -3 : 8.18 m Ohms
+1, -2 : 1.601 k Ohms
+1, -3 : 7.46 m Ohms
-1, +2 : 1.607 k Ohms
-1, +3 : i
-2, +3 : i
+2, -3 : 7.47 m Ohms
+1, -2 : 1.453 k Ohms
+1, -3 : 8.28 m Ohms
-1, +2 : 1.455 k Ohms
-1, +3 : i
-2, +3 : i
+2, -3 : 8.33 m Ohms
+1, -2 : 1.59 k Ohms
+1, -3 : 7.48 m Ohms
-1, +2 : 1.59 k Ohms
-1, +3 : i
-2, +3 : i
+2, -3 : 7.60 m Ohms
ANY HELP IS APPRECIATED! THANKS
Old May 17, 2008 | 04:50 PM
nlmaxima's Avatar
Did you check the end gap on the plugs before you installed them?
Old May 17, 2008 | 06:12 PM
pyroz's Avatar
yea, it was .40-.44. they were the NGK coppers. can they be the problem?
Old May 17, 2008 | 06:23 PM
RacerX1320's Avatar
how come not the NGK IX?
Old May 17, 2008 | 06:32 PM
pyroz's Avatar
i read that the copper provides a better spark and I don't mind changing them every 15k. Do you think the .40 - .44 gap might be the problem? I do notice it idles a little rougher than when I had the original OEM NGK Plats.
Old May 17, 2008 | 06:38 PM
SoonerFan's Avatar
Cletus
well you used the wrong plugs so.....
Old May 17, 2008 | 06:46 PM
pyroz's Avatar
alot of people had success using cooper plugs. Guess i'll go and get some platinum ones tomorrow. Can you please explain why these plugs are wrong? i got the NGK V-power copper. And would a gap of .40 cause the code and rough idling? Thanks
Old May 18, 2008 | 09:16 AM
RacerX1320's Avatar
Our gap is in the .40s so i doubt thats the issue. I didnt gap my IX's when i put them in. Although our cars are VERY picky with its plugs. I remember a guy in here put those crappy Pulstar plugs and the car went into limp mode.
Old May 18, 2008 | 01:43 PM
pyroz's Avatar
i don't know. just read that alot of people use ngk v power copper and its good. o well.
Old May 18, 2008 | 09:31 PM
NisTech's Avatar
why have to take the plenum off every 40 k and have to replace $60 dollar gaskets to save 40??
Old May 18, 2008 | 09:46 PM
pyroz's Avatar
because i said i have a 2000 max. no gaskets and manifolds involved.
Old May 18, 2008 | 10:00 PM
NisTech's Avatar
ups my bad bud, can't seem to find where you wrote that though.
Old May 19, 2008 | 01:55 PM
Dr. Roy's Avatar
I had the same thing happen to me a few years ago, changed plugs and got a P1320 a few days later. It was in fact a bad coil = bad luck/coincidence
Rather than changing all the coils when i got a P1320, i bought some used ones off ebay and replaced them one at a time as they went.
I no longer have the car, and have 2 coils sitting around, if you are interested in them PM me - $40 shipped
Old Nov 13, 2008 | 08:00 AM
hardincah's Avatar
p1320, p0300=crap shoot
Can you check your coils by unplugging them one at a time while the car is running or will it mess something up? I know on older cars you could check the plugs by doing this but I don't know about all this electrical stuff.
Old Nov 13, 2008 | 02:19 PM
hardincah's Avatar
anyone, bump
Old Nov 13, 2008 | 06:22 PM
Nelsito65's Avatar
Yes, you can. Make sure to do that when the engine IS misfiring, not when it's running smooth. As you unplug each one of them at a time, whenever a good one is disconnected, the engine will run even rougher; when you unplug the bad one, there should be no change in the "roughness" of the idling. I had a bad one in my car but ended up changing all of them. I personnaly believe that a set of new ones works better than one new and 5 worn out. (The ones sold by Autozone and/or Amazon.com have the grey dots, sometimes covered by a silver sticker)
Old Nov 13, 2008 | 06:38 PM
djlorec's Avatar
just replaced mine today, yeah that was a little hassle, but manage to do it in 90 min. personally i yhink any ngk plugs will do the job, i put ngk platinium gp (the recommended one is PLFR5A, mine are PLFR5AGP slight but better diffrence). if you are having code i would just buy new coils packs at any local automotive store and test them. in a case if coils would be alright return new ones. no idea what else can give you that code
Old Nov 17, 2008 | 04:42 AM
hardincah's Avatar
aight guys thanks for the help. Diag. test showed I had a bad connection to a fuel inj. on cyl. 2. djlorec-I used the NGK IX they seemed to be pretty good till the shuttering started happening-still a strong car though. Thanks again guys.
Old Nov 17, 2008 | 05:45 AM
sergey85's Avatar
use platnium ngk spark plugs and nothing else
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
