Short Height Shifter project
Old May 24, 2008 | 10:07 PM
  #41
DeusExMaxima's Avatar
Originally Posted by SoonerFan
disagree.....
Old May 24, 2008 | 11:19 PM
  #42
SoonerFan's Avatar
Cletus
To make shifting easier, you have to get weighted shift *****.
and i said that i disagreed that you HAVE to have a weighted ****
Old May 25, 2008 | 12:06 AM
  #43
VQHP's Avatar
Sunglasses required..
disagree.....
you disagree with everybody............you only agree with yourself!
Old May 25, 2008 | 12:12 AM
  #44
SoonerFan's Avatar
Cletus
and who exactly are you
Old May 25, 2008 | 12:22 AM
  #45
ptviperz's Avatar
Old May 25, 2008 | 06:17 AM
  #46
ZIPPIN's Avatar
Mauja He Mauja
Threads would be boring with it
Old May 25, 2008 | 08:31 AM
  #47
zero2sixtyZ's Avatar
You embarrass me.
Interesting. I'd like to keep updated on this for long term reliability. I have the STS mod and ES bushings and this might finish the shifting mods for me. I'd really like to see how it feels when shifting. I'm used to the truck sized shifter.
Old May 25, 2008 | 12:02 PM
  #48
majesticmaxima's Avatar
Finished the installation today, pretty straight forward. I absolutely love this mod, and shifting feels great. A little shorter in throw, not any more effort. But its more comfortable than originally because normally my elbow is lower than the ****, now the **** is lower and feels much more natural. This is the way it should have come from the factory.
Highly recommended mod if you are unhappy with the current set-up. STS next weekend.
Now what to do with my original one?
Old May 25, 2008 | 12:08 PM
  #49
were you concerned about the weld/lock-out failure?
Old May 25, 2008 | 01:06 PM
  #50
before:
after:
Old May 25, 2008 | 03:58 PM
  #51
SoonerFan's Avatar
Cletus
that does look nice...shifts should be greatly improved with the STS and bushings...
Old May 25, 2008 | 04:05 PM
  #52
EnervinE's Avatar
i has college
In those pictures, is the car in 3rd gear? Otherwise...
Old May 25, 2008 | 06:30 PM
  #53
You embarrass me.
Looks great. If I brought you a spare shifter assembly, could you do this for me? You're in CT, so you're not too far.
Old May 25, 2008 | 07:21 PM
  #54
MacGarnicle's Avatar
Could have raised up the arm rest to the higher position...
Looks great though - always thought the shifter stood out like a sore thumb in the 6 speeds. Seems like an all-round worthwhile mod if it has performance benefits in addition to looking great. Nice work.
Old May 25, 2008 | 08:04 PM
  #55
I'm waiting to recieve the bushings and then i will do both for the day
I'm pretty sure it was in first. Why?
I actually bought my car in mass , i dont mind doing it except it will take a few days so... its up to you
Old May 25, 2008 | 08:22 PM
  #56
ZIPPIN's Avatar
Mauja He Mauja
Looks great. Nice work
Old May 25, 2008 | 09:13 PM
  #57
Looks great. Much needed mod. Is it easy to weld. Id need to have it done, so any suggestions for me to tell the welder. What do you think a welder should charge? Does reverse lock out work well?
Old May 25, 2008 | 09:44 PM
  #58
kamski's Avatar
.org extraordinaire
If it works out well i was gonna remove the original and do the same to it.
I will paypal you money for this right now.
Kamski
Old May 25, 2008 | 10:14 PM
  #59
Yayomax's Avatar
still brewin'
Man, the 5th gen looks so much more sucky than the 5.5 gen. Unless its just my car
Old May 25, 2008 | 10:56 PM
  #60
EnervinE's Avatar
i has college
Oh okay same thing. I was just making sure it wasn't in neutral because you'd have a hell of a time getting it into an upper gear.
Old May 26, 2008 | 06:03 AM
  #61
It was tricky to weld because there is a plastic piece molded to the shaft which would get extremely hot if you continuosly welded around the shaft, so i layed a bead then quenched it. Did that process a few times. Grounding the shaft was tricky too.
The reverse lock-out works exactly as it used to, perhaps a little better as i lubed it a little.
I have no idea what a welder would charge or if he would even do the project considering what its for
Old May 26, 2008 | 06:06 AM
  #62
i actually think my shifter still ended up shorter than yours, although i had put a little more work in
Old May 26, 2008 | 06:52 AM
  #63
Whitebread's Avatar
Originally Posted by Kevlo911
Lowering your car is horrible for your suspension geometry
The 2k2 shifter does sit ridiculously high and this is a good mod IMO. Nothing wrong with people wanting their car to look better.
Camber, Caster and Toe measurements at lower ride heights please.
Old May 26, 2008 | 11:28 AM
  #64
Yayomax's Avatar
still brewin'
yours is lower. Looks real good. I cut the threaded section off only. So however many inches that portion is, is how much lower it is. Either way it goes, stock is too high.
Old May 27, 2008 | 11:06 PM
  #65
sunstream453's Avatar
any opinions on using JBweld on the shaft? I feel like i will most likely just rethread the top but if i dont think i will be able to then i will cut it. would prefer to use Jbweld over having someone weld it but if i have to get it welded then fine
Old May 28, 2008 | 02:17 AM
  #66
I wouldn't recommend it, but its your car. I feel that something as important as a shifter modification should be done 100%, no cutting corners so to speak.
If you have a 5th gen, i'm not sure what the shaft looks like, its different.
The 5.5, i dont think cutting the threaded portion is a good idea because the shaft starts to taper and then your looking at machining that down to threading diameter. Then the daunting task of running a die over that a few times.
Old May 29, 2008 | 07:16 AM
  #67
Old May 29, 2008 | 07:20 AM
  #68
Kevlo911's Avatar
Kevlo for President
Go look at the angle your axle sits at when it's lowered
But this is ot...
Shifter looks great.
Old May 30, 2008 | 07:00 PM
  #69
Thanks for the comments,
started the mod on my original one today (cutting the shaft/lock out ect.)
Old May 31, 2008 | 08:37 AM
  #70
MaximusMorpheus's Avatar
That does look nice, how does it drive though?
Old May 31, 2008 | 02:58 PM
  #71
thanks, car drives fine. but ii think it shifts better now
Old Jun 20, 2008 | 10:40 AM
  #72
so, how is it holding up? i did this to mine about a week ago. cut a little more than you (bout 2") and eliminated that lower pin since i decided it doesnt really do anything. only difference without the lower pin is that the revers lock-out will spin in circles and detach from the purple slider. nothing a little black RTV didnt take care of. reason im asking is that my lockout sleeve was doing great, and then out of nowhere yesterday it broke the epoxy bond, so i had to pull the boot off and lift the slider by hand anytime i wanted reverse. hopefully yours didnt do that. im gonna apply extremely generous amounts of epoxy to it tonight. then when it dries, apply another ridiculous amount to it. lol. hopefully your epoxy was a little better. mine was SUPPOSED to be 2 ton...guess it wasnt 2 ton shear modulus
Old Jun 20, 2008 | 11:31 AM
  #73
Mine has been fine, i love it.
As for the reverse lock-out, the lower pin that you removed is there to limit sheath travel and rotation. The sheath should only move like a quarter of an inch or so. I dont understand how yours broke. Did you rough up the plastic enough to get a good bond? What did you use the RTV for?
Old Jun 20, 2008 | 12:37 PM
  #74
yeah, i thought about that pin for a while and knew what i was doing when i removed it. i just made sure that when i cut the sheath that i had it just right as far as using the shift **** to limit travel, that part works well. i roughed up the plastic, but i feel like i just didnt really get enough on there to get a good bond. it should be better this time. the RTV i used to keep the sheath from rotating, since i took the lower pin out of the equation. i sealed the sheath onto the purple slider by putting some RTV into the connector between the two, that part works well too. overall i really like the result and i cant wait to race on it soon. the only problem has been the sheath connection and that oughta be an easy solution
Old Jun 21, 2008 | 11:55 AM
  #75
Do you have any pics of it? id like to see some. You welded the pieces together? Good luck with the repair on the lock out.
Old Oct 16, 2008 | 10:49 PM
  #76
How are the shifters holding up? Anyone else try this?
Old Oct 17, 2008 | 12:05 PM
  #77
no problems with the shifter. I love this mod BTW. My original one will be ready shortly if anyone is interested. I had to put the project on hold for a while, so its taken longer than i expected.
Old Oct 18, 2008 | 07:24 AM
  #78
nismowolfe's Avatar
Wow looks great awesome job great write up and pics. I wish I had a six speed and I would definatley do this. Now enjoy you great work.
Old Oct 18, 2008 | 02:16 PM
  #79
knight_yyz's Avatar
Toolie
What on earth did you use to 'quench' it? I hope not water. If so I think you got lucky. You can't heat something up to red hot and then dunk it in water. Use an air gun. How much room is there in the plastic sleeve? Just wondering if you could put a metal sleeve where the weld is and then weld above and below
I think this would work better (if there is room) and you can guarantee the shaft will stay straight
Old Oct 18, 2008 | 04:23 PM
  #80
The Shift lever never reached "red hot" temperatures as you implied. Yes water was used to quench the metal.
I don't understand the plastic sleeve idea you had. Why would you use a metal sleeve? For support? The plastic sleeve does not go to the bottom of the shaft where the wweld is. The weld is solid and has never moved or bent. I wanted to retain the plastic sleeve for the reverse locckout functionality. thanks
