Roaring sound from passenger side on hard acceleration
Old May 26, 2008 | 08:10 PM
Love_00_Max's Avatar
I hear roaring sound from passenger side pulley area (not from wheels since I changed my bearing recently and the humming sound of a worn out bearing will ring in my ears for sometime for me to not forget it...).
Is it sign of a worn water pump? When I acclerate under load on steep inclines the roar is quite evident but then when I come back to flat roads it is silent as a cat... (BTW, I have been slowly loosing coolant too but not dipping anywhere to determine it is a water pump).
Any suggestions will help...
Old May 26, 2008 | 08:22 PM
SoonerFan's Avatar
Cletus
bad alternator
Old May 26, 2008 | 11:32 PM
CMax03's Avatar
about checking all your belts and their tension!
Old May 27, 2008 | 01:09 PM
sublime258's Avatar
I am sort of having the same issue. I installed a grounding kit yesterday. When I was grounding the timing chain cover, I accidentally dropped the bolt and it went into the pulley/belt area. I searched for like an hour with a flashlight but couldn't find it, and it definitely didn't fall through to the floor. I eventually gave up and figured it would fall out. My car is running great with the grounding kit, but now I can hear some type of "roaring" sound coming from the pulley/belt area too, only when I'm hitting the gas though. Hope I didn't f*** anything up .
Old May 27, 2008 | 01:42 PM
Colonel's Avatar
Old Fuddy Duddy
Originally Posted by sublime258
...When I was grounding the timing chain cover, I accidentally dropped the bolt and it went into the pulley/belt area....and it definitely didn't fall through to the floor. I eventually gave up and figured it would fall out. ....now I can hear some type of "roaring" sound coming from the pulley/belt area too....Hope I didn't f*** anything up .
Amazing
03VQMAX
Dec 7, 2015 04:59 PM
lux97Max
Sep 14, 2015 03:54 PM
KGMtech
Aug 18, 2015 09:21 AM
jchronis2552
Aug 13, 2015 07:48 AM
follyburr
Aug 7, 2015 09:50 PM
