Guage Lighting Problems
Old May 27, 2008 | 08:32 PM
Eastern's Avatar
Since I bought my 01 SE back in April of 07 my tripometer guage has not been lighting up off and on, but now none of the guages light up (including my tac and speedometer) they come on randomly but it is very rare. Has anyone ever had this problem and been able to fix it?
Old May 27, 2008 | 08:47 PM
foodmanry's Avatar
Da Roller Coaster!
It sounds like a loose connection. I would pull the gauge cluster out and check the connections. Make sure when you re-install they are all tight.
If you do this and its still happening I would look at replacing the bulbs behind the cluster. I'm probably going to be replacing mine because the light output is getting pretty low. It is a simple procedure, but I think the bulbs may be a bit expensive...not sure though.
Old Jun 7, 2008 | 11:20 PM
hi-tek22's Avatar
where can one purchase these bulbs from........ because the bulb that lights up my engine temp, and RPM's finally died out on me and i need to replace it
what number are they....i could have sworn that i read somewhere it was 194??? IM SURE IM WRONG THOUGH
Old Jun 8, 2008 | 01:37 PM
knight_yyz's Avatar
Toolie
#74
Old Jun 8, 2008 | 09:25 PM
hi-tek22's Avatar
I USED #2723 sylvania's
lol, i also found the bulb number right at the bottom of the socket you put the bulb into......the 2723 seem brighter to me, maybe its because i had a pick of the cheaper bulbs and then the 2723's
the bulbs i got are 13.4v, and operate at 2.3 watts....
Would any one know if getting the #74 white LED's would be better or to just stick with these "soft white" bulbs
Old Jun 9, 2008 | 12:25 AM
2000MaximaSE's Avatar
ya get the white leds from autolumination.. they are way cheap and so is shipping.. I put them in the analog clock of my I30.. looks SICK
Old Jun 9, 2008 | 06:28 AM
hi-tek22's Avatar
^^YOUVE SOLD ME, lol
I just ordered 4 of those 4.99 white LED's!
thanx for the input
Old Jun 9, 2008 | 11:38 PM
Here is how they look in my clock
Old Jun 10, 2008 | 11:04 AM
hi-tek22's Avatar
WOW THAT LOOKS DAMNED GOOD........
*awaiting my white LED's anxiously*
tsi6001
Oct 3, 2022 10:23 PM
Cotozic
Jun 28, 2017 08:01 PM
95Maxi
Aug 25, 2015 08:01 PM
Samedi
Aug 13, 2015 04:05 PM
yat70458
Aug 3, 2015 01:16 PM
