5th Gen Blacked out headlights
Old May 28, 2008 | 06:40 PM
T3hGman's Avatar
Hey guys i need some help.
Im looking for a way to black out my headlights and fog lights.
I have a few options but dont know what to do.
1. I can buy the black lights on ebay or buy the AE headlights but this costs a decent amount.
2. I could open up the headlights and spray paint them myself
3. I could buy precut headlight tints online
What do you guys suggest, can anyone advise on where to find these options or how to do these?
Does anyone have pics of the 5gen headlights tinted or sprayed?
Thanks!
Old May 28, 2008 | 06:47 PM
ZIPPIN's Avatar
Mauja He Mauja
Get ready. In the meantime read this:
1. Go for it !!!!
2. Yes you could
3. Yes you could
Search is your best bet:
http://forums.maxima.org/showthread.php?t=560236
Old May 28, 2008 | 11:05 PM
Jess's Avatar
SHIFT_In2D
I've blacked out a few headlights for the locals.
Read Housecor's How-to for baking/opening headlights.
http://www.innerbean.com/housecor/clear_HIDs.html
Open and take out the trim/housing that you want blacked out. Mask off any areas like the reflector with masking tape.
Lightly sand with 600 grit so that the paint will stick.
You can do 2 things.
Primer
Color
Clear
Or just a black plastic krylon gloss paint will work.
Now that I use a spray gun it comes out more glossy than your normal spray can paint job. So make that 3 ways you can black out your head lights.
Let dry, and place the headlights back in the oven to re-heat the glue. Seal together with clamps and then install!
This would be the cheapest way and you'll feel more accomplished.
Best pic I've got of one set of headlights I did...matched the car well.
Old May 29, 2008 | 08:04 AM
T3hGman's Avatar
baking the headlights will only affect the glue?
will it melt the sprayed on paint once i put it back in the oven?
Old May 29, 2008 | 08:19 AM
amtrucker22's Avatar
I tried the tint for my truck and had a hard time with curves. I am by no means semi-qualified to tint though
Old May 29, 2008 | 08:24 AM
scheibler's Avatar
You should do the AE mod yourself IMO. Get some silicone at autozone to reseal the headlights and preven condensation though. The paint should be fine in the oven. If you really want to be safe get some caliper paint or another type of paint with high heat tolerance.
Old May 29, 2008 | 08:34 AM
phatboislim's Avatar
didnt know you did lex's car..
i'm scared to put my headlights in the oven...or even to attempt to take the lights apart..
Old May 29, 2008 | 11:18 AM
Jess's Avatar
SHIFT_In2D
I cleared the signal and blacked em out. I'm good for the cosmetic mods. Also did MattyBlacc's headlights except he wanted the orange signal lense.
Let the paint dry and then bake it helps the paint adhere to the plastic too.
No probs with seal or condensation if done right plus looks better than having a bead of silicone.I've done headlight mod for four people blacked out 2 of those 4 and its been about a year and a half everyones lights are doing fine.
Remember to use a pan not the rack or you will melt lines into the plastic.
Old May 29, 2008 | 11:22 AM
T3hGman's Avatar
i have seen people do it to the 5.5gen lights but i havent seen anyone do it to the 5gen lights, is there a diff in the headlights that i should worry about as far as putting them in the oven, like difference in glass/plastic?
and what should i do for the fog lights?
Old May 29, 2008 | 12:00 PM
i argh scared
Old May 29, 2008 | 01:00 PM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
if you have 5th gen it is even easier. just bake them and then rub off the chrome, no paint needed. gives a glossy black color. really easy to do. search AE Headlight Mod. as for the fogs. I bought some ebay ones. smoked...
the output isn't so great if you're using regular bulbs. it basically dims the inside housing. I'm using HID's so i guess its a decent balance between day/night looks for me anyways. hope that helps )
Old May 29, 2008 | 06:31 PM
T3hGman's Avatar
how do i rub it off?
like a towel and some plastx?
what kind of paint could i use to give it like a mat black look
Old May 29, 2008 | 09:00 PM
Jess's Avatar
SHIFT_In2D
For matte black...I would not recommend a clear unless you use a satin clear.
Otherwise look for "satin/matte" black finish.
Krylon Plastics is pretty good, and the only matte finish in Duplicolor paint is the black sandable primer which I don't quite recommend.
Old May 30, 2008 | 11:22 AM
Maxima112's Avatar
well when you take off the front lens all you need to rub is the front trim. you'll need hot water and a towel. just rub in circle or whatever you want and then dry it off really well so you dont get condensation later. this will leave a glossy black finish, basically for free his is 5th gen only...5.5 needs to be painted. juuust to make sure you understood.
Old Jun 11, 2008 | 04:54 PM
adrenaline_rush_fanatic's Avatar
I just got in my gravity feed spray gun in today
I'll be doin this soon.
black w/clear
Old Jun 11, 2008 | 07:19 PM
Maximized2000's Avatar
My detailed writeup that I did a while ago:
http://www.cardomain.com/ride/2190617/3
My headlights still looks great and I have NO condensation whatsoever.
Old Jun 12, 2008 | 09:00 PM
rev2red's Avatar
i wanted to black out my headlights but i cant adjust my lights cause the **** wont move the light i see it a common problem with the 5.5 what are my other options? do i need new headlights?
Old Jun 16, 2008 | 02:20 PM
TDotMax's Avatar
Did mine in my '00. You do not need paint at all. just hot water/soap and some elbow grease and the chrome will come off to reveal a gloss black finish.
Old Jun 16, 2008 | 04:22 PM
choiiiiiiiiiii's Avatar
Old Jun 16, 2008 | 04:56 PM
TDotMax's Avatar
Originally Posted by choiiiiiiiiiii
No idea where you are heading with this, but once you open up the stock 00-01 headlight housing, the chrome is cheap film that will come off. The chrome trim un-screws from the housing and scrub in hot water reveals a gloss black finish. No need to waste money on sand paper, paint or primer.
Old Jun 17, 2008 | 09:14 PM
redrelyt12's Avatar
Old Jun 17, 2008 | 09:17 PM
Professor's Avatar
Just did mine today, came out good, I did notice that the chrome comes off super easy if your not carful.
Heres a pic.
Old Jun 17, 2008 | 09:31 PM
hi-tek22's Avatar
^^looks good man, i cleared my 2k2 headlights and one of them i actually melted the bracket that holds the ballast, RENDERING THAT HEADLIGHT usless
SO word of caution, its always a good idea to use a small DAMP hantowel on the cookie sheet or what ever you use so that it does mess with the plastic...one downside is CONDENSATION could get, which quickly evaporates when the light is taken out.....not a wet towel is necessary, just DAMP all over the towel
Old Jun 17, 2008 | 09:40 PM
Professor's Avatar
Yeah, i actually wrapped my light in a dry towl, 200F for 20 mins, poped right open, when i closed it, i did it at 250F for 10 mins and it went together like peanut butter and jelly.
Old Oct 15, 2008 | 11:34 PM
AbSoLooT's Avatar
Just did mine, turned out awesome. Took longer than expected, and those little clips that hold the screws are weak sauce. But besides, very happy with the results.
Old Oct 15, 2008 | 11:41 PM
hi-tek22's Avatar
take some pics and post em
Old Oct 16, 2008 | 09:00 AM
redrelyt12's Avatar
I want to do this also. Does anyone know the best way to clear up the foggy lenses?
Old Oct 16, 2008 | 10:42 AM
ZIPPIN's Avatar
Mauja He Mauja
Check this:
http://forums.maxima.org/5th-generat...cs-inside.html
Old Oct 16, 2008 | 12:04 PM
Jreed2008's Avatar
Painting the lights are easy but you Might as well add halo's or clear signals while your at it because having to keep baking your lights can be a pain. I had to do mine around 5 times because of the epoxy seperating from the halo's. got pics on my page
http://www.cardomain.com/ride/3072157
Old Oct 16, 2008 | 04:26 PM
jattdemax's Avatar
just take them apart, and scratchx the chome off, no need to paint. best mod i've even done. cost me 0$, and changed the whole look of the front end.
Maxima_Joe
Nov 25, 2015 08:19 AM
Finkle
Sep 27, 2015 09:53 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
