Blew an O2, is an O2 simulator the way to go?
Old Jun 4, 2008 | 06:14 PM
PearlWhtMaX2000's Avatar
My check engine light went off, and i got the code pulled. It was rear bank
O2 sensor. I think i am going to keep blowing it, so is it better to get an O2 simulator? also where would be the best place to get one, and how much do they usually run compared to a regular O2 sensor?
Thanks in advance
Old Jun 4, 2008 | 06:37 PM
choiiiiiiiiiii's Avatar
sims are cheaper
o2simulator.com
and blowing the o2 sensor? what's that mean..
Old Jun 4, 2008 | 07:20 PM
bigj01AE's Avatar
so which one of those sensors works in our cars?
Old Jun 4, 2008 | 07:25 PM
Love_00_Max's Avatar
NO. Simulators are stop gap arrangements.. Eventually you will get the heater code and that is not fixed via a simulator. Good luck with sims...
Old Jun 4, 2008 | 07:28 PM
majesticmaxima's Avatar
Thanks in advance
IF the light went off you wouldn't have codes right?
Why not fix the problem? If the sensor is failing multiple times that might mean there is another problem. I'd start there.
Old Jun 4, 2008 | 08:00 PM
that's why you sim the heater as well.
haven't had a prob. with my sim for a long while now.
Old Jun 4, 2008 | 09:33 PM
I went to o2simulator.com, which one do i need exactly?
Old Jun 4, 2008 | 10:15 PM
SoonerFan's Avatar
Cletus
you didnt "blow" a sensor...it just wore out...they are wear items.
why dont you just fix the problem the right way
Old Jun 4, 2008 | 10:17 PM
sunstream453's Avatar
because buying a real downstream 02 is extra price with no benefit???
Old Jun 4, 2008 | 10:20 PM
IHAVEA2KMAXIMA's Avatar
i thought o2 monitors your air/fuel mixture?
Old Jun 4, 2008 | 10:22 PM
SoonerFan's Avatar
Cletus
sims are needed when the air/fuel is different because of a mod (headers)...in this situation, the sensors will wear out quicker.
if this doesnt apply to you, you dont need a sim...do it the correct way and get the sensor
Old Jun 4, 2008 | 10:24 PM
SoonerFan's Avatar
Cletus
they do....they determine if there are excess emissions because the car is running rich...the ECU then changes the mixture
Old Jun 5, 2008 | 09:06 AM
well my entire airflow system is modified, so i think o2 sim is the way to go. I just cant tell which one i need from that site
Old Jun 5, 2008 | 09:45 AM
mtrai760's Avatar
'Trynna' is not a word
You'll pay to modify your entire airflow system, but you'll cheap out on replacing an O2 sensor that will optimize your vehicles performance? :
Old Jun 5, 2008 | 02:51 PM
how much does a new o2 sencor go for? whats the best place tobuy from?
Old Jun 5, 2008 | 02:56 PM
SoonerFan's Avatar
Cletus
daveb
around 150
Old Jun 5, 2008 | 03:49 PM
Squirrel82's Avatar
http://www.o2simulator.com/
Universal dual output o2 sensor in my 02 for about a week.No codes.
Old Jun 6, 2008 | 06:38 AM
NmexMAX's Avatar
dot dot dot ...
1.) Do not sim. your primaries.
2.) A33B's do not need sims for the secondaries, even with headers. Just add a bung so that you do not have to extend the wires, and you'll be ok.
Old Jun 6, 2008 | 01:48 PM
SSandMaxima's Avatar
a "bung"?
Old Jun 6, 2008 | 02:09 PM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by SSandMaxima
a "bung"?
Threaded hole in the exhaust stream (header / b-pipe) which accommodates an O2 sensor and its thread.
http://forums.maxima.org/showpost.ph...45&postcount=4
Old Jun 6, 2008 | 06:09 PM
Squirrel82's Avatar
Didnt know about the bunghole.Too late for that.
Old Jun 6, 2008 | 07:35 PM
blkAEmax82's Avatar
Glory Glory Man United
I really wish i knew this. I followed the headers thread on top of the 5th gen forum. It did mention to get some bungs made, but that you needed to extend the wires cause it would have to be by the Bpipe.
Old Jun 6, 2008 | 11:57 PM
NmexMAX's Avatar
dot dot dot ...
Yes, this is a new 'discovery', as I have noted this with myself and another member w/ headers.
Puppetmaster, we need to talk.
Old Jun 7, 2008 | 06:03 AM
If you have 80K on the motor you are better off replacing all the sensors and moving on. 2K maxima's coils were faulty from the get go, they fouled up the sensors pretty fast on my car. Replaced coils at 60K and sensors a little later (bought the 4 from www.ngk.com) and now I have close to 150K on the motor. No codes, no nothing, the vehicle drives like a charm.
BTW, once you hit 80K you should replace the O2s even if they don't throw codes. With gas at $4.39/G you are better of not have a lazy sensor doing nothing to improve F/A ratio. I bet one will recover the cost of the sensors by driving at around 70MPH with better MPG.
Old Jun 7, 2008 | 07:18 AM
RLW001's Avatar
An O2 sensor is a wear item, just fix it correctly by replacing it and be done with it.
tsi6001
Oct 3, 2022 10:23 PM
QueensMAX
Sep 15, 2015 04:14 AM
kjlouis
Sep 14, 2015 11:22 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
