leaky radiator
Old Jun 10, 2008 | 12:19 PM
serin's Avatar
leaky radiator
so my 5th gen cali SE is leaking coolant.
mechanic hooked up a hand pump pressure thingy and it's leaking from a corner of the plastic tubing that runs across the top of the radiator, just under the air intake scoop.
my question is this, will jb weld work??? does it even adhere to plastic and if so how would i perform with pressure?
i'm sure i'm not the first one to leak coolant.
any help or ideas is appreciated.
thanks.
Old Jun 10, 2008 | 12:26 PM
mtrai760's Avatar
'Trynna' is not a word
Just replace the radiator.
http://forums.maxima.org/showthread.php?t=365299
Old Jun 10, 2008 | 12:37 PM
AceofSpds's Avatar
wat
Originally Posted by mtrai760
+1
JB weld or quick steel will help slow the leak allot but isnt a permanent fix, I used some on mine when i had to wait for my koyo to get shipped. Also more leaks will start to show up on your radiator, i noticed after i sealed up the leak on mine i noticed where coolant was starting leaking in a few other spots.
Old Oct 19, 2008 | 02:44 PM
00MAXI's Avatar
Ok I just found out I have a very similar problem. Now where did you buy your radiator and how much is install
Old Oct 19, 2008 | 02:46 PM
00MAXI's Avatar
Man I've noticed the cooling system is the worst in the Maxima. I've replaced thermostat, both radiator hoses, and BOTH freakin fans to fix an overheating problem I had a year ago. Now it seems like the radiator.
Old Oct 19, 2008 | 03:08 PM
Nelsito65's Avatar
+2 on replacing the radiator.
Delaying that may cause overheating issues which will lead to co$$$tly engine damage (taken straight from my experience on a Camry I used to have years ago).
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Gingerheadman
Oct 1, 2015 05:11 PM
dcam0326
Sep 7, 2015 07:26 AM
