6th gen intake on 5.5 gen
Old Jun 25, 2008 | 08:27 AM
ervmiranda's Avatar
Does anyone know if you can install an cold air intake from a 6th gen to a 5.5 gen.
Old Jun 25, 2008 | 08:30 AM
NmexMAX's Avatar
dot dot dot ...
MAF bolt pattern is different, and the tubing might be a little different, but nothing a little elbow grease and thought process couldn't over come. What were you thinking of, exactly?
Old Jun 25, 2008 | 08:31 AM
nismology's Avatar
Moved.
Old Jun 25, 2008 | 08:56 AM
mist max2000's Avatar
interested in responses...which one were you thinking... fujita? ..
Old Jun 25, 2008 | 09:27 PM
JoshP2002's Avatar
edit; Im thinking of a short ram air intake, I dont know if a true CAI is different.
Its not worth the heart ache.
I have a K&N intake, and will be doing a battery relocation because of it..
The piping puts the filter right into where your battery is located. If you look at a 5.5gen to a 6th gen, there is a 90 degree turn in the battery. So your battery will not fit with the piping.
Otherwise the MAF sensor doesnt fit either, both a different bolt pattern and depending on the thickness of the piping, is too long. My piping is.. 3" I believe? And it sticks out about a half an inch, I had to make up some stuff to hold it in there.
edit; If you're not willing to move the battery to the back, there is adequate room to attempt moving the battery tray 90 degrees like that in a 6th gen.
Also, the metal bar that holds the intake into the vehicle does not line up with any bolts on the 5.5gen
Old Jun 25, 2008 | 09:35 PM
User 12822's Avatar
just do GAB mod manng
Old Jun 29, 2008 | 02:13 PM
VqMoNsTeR's Avatar
go to autozone. they make a one piece pipe u can cut. every max on this side is running it with no probs, including me. 45 bucks
Old Jul 2, 2008 | 11:08 AM
ervmiranda's Avatar
I was thinking either injen or fujita.
Old Jul 2, 2008 | 11:15 AM
McSteve's Avatar
if you haven't bought it yet, why wouldn't you just buy one that fits your car???
Old Jul 2, 2008 | 11:22 AM
ervmiranda's Avatar
I already have an injen on my 02 but its not a true cold air intake.
MAXSE5SPD
Sep 17, 2022 04:00 AM
BkGreen97
Apr 2, 2016 05:47 AM
A32goldylocks
Sep 2, 2015 06:39 AM
Lowered_a33
Sep 1, 2015 07:49 PM
