2001 MAXIMA AUTOMATIC STALLING AND ROUGH IDLE
Old Jun 29, 2008 | 08:21 AM
JoE'sMaX01's Avatar
HEY ALL,
BEEN A WHILE SINCE I'VE POSTED SOMETHING UP HERE BUT HERE IT GOES.
I'VE BEEN HAVING PROBLEMS WITH MY 2001 MAXIMA AUTOMATIC.
CAR HAS BEEN STALLING WHEN IN PARK, NEUTRAL AND NOW IT'S STALLING WHILE IN DRIVE. HAD THE ENTIRE THROTTLE BODY CLEANED, REPLACED THE GAS FILTER, CHANGED MY ALT.
I NEVER HAD THE CAR STALL ON ME IN DRIVE INTILL ABOUT 2 OR 3 DAYS AGO IT HAPPENED AT A RED LIGHT.
THE CAR IS ALSO CHOKING WHILE I'M SLOWING DOWN TO COME TO A STOP AND GIVES A ROUGH IDLE.
ANY IDEAS??
Old Jun 29, 2008 | 09:36 AM
MAXIMA_STYLE's Avatar
Check your sensors, IAC could be shot...
Old Jun 29, 2008 | 09:43 AM
JoE'sMaX01's Avatar
How can I find out if the IACV is shot? Anyone know of any ways to determine if this is the case?
Old Jun 29, 2008 | 10:30 AM
Teddie18's Avatar
To confirm if the IAACV is bad you have to check the voltage between the harness pins and the ECU. Download the Maxima FSM and it will give you the procedure. Its not very difficult to do.
Old Jun 29, 2008 | 10:43 AM
JoE'sMaX01's Avatar
Thanks I'll look into that as well.
But I have a question , anyone know if this could be caused by an electrical short of some kind in the car? I do have a system in my car and for some reason even with my cap my lights dim both inside and outside on the car and the volume isn't up high either. As well when I have my GPS plugged into my front cig socket I can tell that the car is lag in power and starts to hesitate more and become more likely to turn off on me...
Any ideas on this theory ??
Old Jun 29, 2008 | 12:44 PM
Well depending on how large your system is you could be putting a huge drain on your battery but that wouldnt cause your car to stall, its just going to kill your battery over time, i suggest upgrading to an Optima battery, probably in your case , the red top , but i got a system in my car with 2 amps and dual voice coiled subs and my lights dont dim even without a cap....
Old Jun 29, 2008 | 01:21 PM
JoE'sMaX01's Avatar
Well I have had problems with battery in the past where I've need to get a jump to start the car. I already changed the Alternator on the car as well as my Starter in that last 3 months. I wouldn't say my system is that big to cause such a huge drain its one amp thats 2000 watts and 2 rockford subs with a 5 Farad Cap. The battery is fairly new changed in 2006/07 with a ACDelco Battery. But I might try your suggestion and try the Optima battery. I'm sure this will help with the dim lights and stuff but I know it won't do nething for the stalling of the car while in drive or idling in park or neutral. I'm stumped on what is going on here. I'm thinking of maybe trying to change out the MAF sensor see if it does nething.
Old Jun 29, 2008 | 01:24 PM
JoE'sMaX01's Avatar
Oh and btw I don't have any CEL or SES popping up on my dash. Car says everything is fine. My mechanic told me it could be a transmission valve? or something like that but that cost money and it needs to be done by a transmission expert.
Old Jun 29, 2008 | 03:16 PM
stalling could be cause my numerous different things, ive owned cars in the past where it was just a simple spark plug change in cylinder 1. Although, it was an american vehicle versus a nissan, it should still all have the same applicable troubleshooting, check your plugs,sensors,clogged cats of do that also (had a cavalier that did that to me).
Old Jun 30, 2008 | 08:22 AM
JoE'sMaX01's Avatar
Interesting thing I found out yesterday was my car won't stall or suffocate or hesitate while either in drive/park/or neutral if I keep my AC on front defrost. Seems that if the fans are working the car will not shut off or anything.
Anyone have any thoughts about this? And why would the having the AC on keep my car from Stalling or having the RPMs drop below 500?
Old Jul 3, 2008 | 02:34 PM
JoE'sMaX01's Avatar
bump...
can anyone tell me what kind of cleaner would be good to use for the MAF sensor?
Old Jul 3, 2008 | 05:56 PM
hi-tek22's Avatar
Originally Posted by JoE'sMaX01
bump...
Get this stuff.....its called CRC Mass Air Flow Cleaner...pick it up at autozone, pepboys, advanced auto....what ever u choose
A quick search could have revealed this (for future reference though)
Old Jul 3, 2008 | 08:16 PM
maxinthusiest's Avatar
Ditto on the mass air cleaner, I had the same prob and it took care of it.
Old Jul 4, 2008 | 12:35 PM
Drockb418's Avatar
i would save for a new maf thats only a bandage to fix that prob.
kjlouis
Nov 24, 2018 06:09 AM
District
Aug 15, 2015 08:23 PM
follyburr
Aug 12, 2015 08:57 PM
Maxboy23
Aug 11, 2015 11:59 AM
wpr
Aug 5, 2015 03:28 AM
