'01 GXE Service Engine Soon light on
Well, my '01 Maxima GXE service engine soon light suddenly came on while I was driving home.
No symptoms whatsoever. It's got 83k miles on it and no engine/exhaust mods. The service engine soon light never came on before.
Anyone got any ideas? Thanks!
Just pulled the code at Autozone.
P0420 = Catalyst efficiency below threshold bank #1
Explanation: The oxygen sensors monitor the catalytic converter's ability to store oxygen.
Probable causes:
1. Catalytic converter defective
2. Engine misfire or running condition
3. Large vacuum leak
4. Engine oil leakage into exhaust-valve guide seals, piston rings
I cleared the code and on the way driving back (8 miles) the light didn't turn on again.
Any suggestions? Due to the fact of recent oil loss, I suspect it is #4.
Probable causes:
I've heard that you can get that code if the gas cap isn't on tight enough the same thing used to happen to me and after removing the cap and putting it back on the sel would go away after driving for a while... or it could be the o2 sensors... but after clearing the code and it not comming back I would suspecious of the gas cap.
There are about a zillion threads on PO420.
Short answer: it's usually an 02 sensor gone bad.
Long answer: there are other causes (including ECU glitch).
Do a search (type P0420 into the search box!), and you will find more threads than you'll ever want to read on this subject.
Ray229Harris
Sep 16, 2015 08:16 PM
rbaker100
Aug 28, 2015 08:11 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
