Which ES polyurethane bushings are worth installing besides rear trailing arm?
I have had a full set of ES bushings in my garage for a while now:
front control arm
subframe
front swaybar
and rear trailing arm
I searched and found that the bushing for rear trailing arm is def worth it. But in searching about results for the others, I've read that the LCA, subframe, and swaybar bushings don't do much...
I have 32,xxx on my car so I'm sure my factory bushings are in OK shape, should I even spend the $ to install the others besides rear trailing arm?
front control arm
subframe
front swaybar
Actually the rear trailing arm really isn't worth it unless yours are cracked. If they are you will see grease running down the trailing arm.
You should do the swaybar and subframe. They are really easy and help. My control arms were fine so I didn't touch those. They can be difficult to install and require the remove of the LCA. At that point you would want to get new LCA's and install the bushings on those. That'll make them good for a long, long time.
What is prompting you to ask about ES suspension components?
Well since you have them already...install them, at least the easy ones (subframe and swaybar). You shouldn't have to worry about them for the life of the car pretty much.
Now the LCA and rear trailing arms...how adventurous to you feel? Or how much are you willing to pay to have them installed? As long as you don't have issues with the those areas then I wouldn't touch them. Maybe just hold onto the ES parts just in case.
I have to get an alignment done, and at the alignment shop they wanted to charge me over 700. They said my LCA bushings are bad, and since they can't be replaced (which is not true as we know) they wanted me to buy 2 new LCAs and the left Tie rod. I'm gonna buy the ES LCA bushings from Brian Catts, and he knows an awesome mechanic in my area that will install em. Saves a lot of dough NOT having to buy the LCAs.
Huttig2009
Sep 25, 2015 03:31 PM
Dman1989
19
Aug 17, 2015 03:44 AM
00 Max
Aug 4, 2015 07:09 PM
