2k2 I35 Wood trim Kit??
Old Nov 6, 2001 | 07:46 PM
2002 SE TX's Avatar
I think the basic dash and console layout on the 2k2 Max and I35 are the same... would the "wood" trim from the I35 fit on a Max? I saw an ad for the I35 and I like the light wood color better than the mahogany-looking stuff available from Nissan. I saw there is a rocker switch on the I35 console to the lower left of the shifter. Is that for the sunroof? Traction Control? I don't have either of those on my 2k2 Max, but I guess I could put a dummy switch in there and label it "PASSENGER EJECT."
Old Nov 7, 2001 | 05:21 AM
jazzy8's Avatar
I think that switch is for the rear window sunshade.
Old Jul 10, 2002 | 06:17 PM
pablopic's Avatar
Re: 2k2 I35 Wood trim Kit??
any luck in locating the i35 kit...does it work? I also perfer the wood trim on i35
Old Jul 10, 2002 | 07:14 PM
perrymaxima's Avatar
The trim on the door arm rest won't work they are different from ours basically the only pieces we could use would be the piece around the shifter. The center councel is slightly diffrent as well (cup holders) They are coming out with more wood on the 2003 I35 according to nissannews.com. You can buy an aftermarket wood dash kit w/I35 colors but they will most likely be flat. I have a molded kit im my max but it is the factory match.
Old Jul 11, 2002 | 05:18 AM
pablopic's Avatar
Re: Re: 2k2 I35 Wood trim Kit??
thanks for the info..it helped..regards
TallTom
57
Oct 14, 2025 05:16 PM
Redfox
Sep 28, 2015 10:41 AM
Pied
Sep 26, 2015 03:29 PM
