Gauging Interest: Billet 5.5+ Gen Maxima MAF Adapters and/or MAF Tubes
Old Aug 2, 2008 | 02:19 PM
HTPerformance's Avatar
Dear Mods, if you feel this needs to be elsewhere, please relocate.
I am thinking about making a batch of MAF adapters or 3" maf tubes (not requiring an adapter plate). Trying to see if there would be people interested.
Please post whether you would be interested in a MAF adapter or a MAF tube.
Pricing would likely be around:
$50 for the billet MAF adapter
$90 for the MAF tube
The tube would have a billet aluminum MAF flange tig welded onto a 3" aluminum tube with bead rolled ends.
Note: The MAF diameter can be changed if there is a need to go larger or smaller.
Here is an example of a MAF Tube we produced for the Ford Focus Community:
http://htperformance.net/index.php?p...emart&Itemid=1
The reasoning behind this inquiry is another 5.5 gen owner has asked us if it was feasible to make him one. He wasn't satisfied with the quality of the welding on the Berk Technologies intake as well as the lack of bead rolled piping. This is also a great idea for those of you who might be looking to make your own short-ram or cold air intake or forced induction setup (turbo or supercharged). We have done a lot of one-off products for the Ford Focus and my experience with the 3rd gens has brought me back to the fold with the 5th+ gen products.
Looking forward to seeing how we can help the Maxima and Nissan Community!
Cheers,
Brian
Old Aug 3, 2008 | 09:14 AM
Torgus's Avatar
i'd be interested.
Old Aug 3, 2008 | 09:24 AM
If you could post which one you are more interested in that would be more helpful. (Adapter or Replacement Tube)
Old Aug 4, 2008 | 07:45 AM
zero2sixtyZ's Avatar
You embarrass me.
I think this would gain more interest in the 5th gen forum.
Also, kinda confused what difference is the MAF adapter versus the MAF tube?
Old Aug 4, 2008 | 08:06 AM
Here are some pictures of the MAF Adapter (from the Berk Technologies kit) sent to me.
I consider this poor aluminum welding (poor quality in general) as does the member requesting that these be made. I would rather see a billet piece or something like our replacement MAF Tubes be used (pictured in the first post).
Old Aug 4, 2008 | 08:23 AM
nismomaxct's Avatar
I would be interested in a replacement tube especially if it was going to be 3".
Old Aug 4, 2008 | 08:25 AM
Torgus's Avatar
basically the tube you want to sell us is 3'' ID, stock is what 2.75''? so it would be bigger aka more air. however the TB will still be the same size 2.75. so gains will likely be minimal. also you would probably want to have an AFC and do a tune when you installed this as the MAF will be reading the wrong amount of air. in theory assuming you can stuff more air pass the TB with this larger piping the car would then run lean as there is more air but less fuel. now the cars do run slightly rich from the factory but i'd rather run rich then lean any day. especially when i don't know how much leaner i would be. also afaik there are no TBs that are 3'' for our cars which again makes one question the gains...
anyone please correct me if i'm wrong in anything i said above...
op: if i were you i'd make a 3'' place racing style intake and sell it as a whole unit, pipe, filter, etc, as its the best after market intake for our cars. i think you would get more business...and try to find someone to make 3'' ID TBs for us...
edit: most people who buy this will need a new filter unless they can cram there old one on. and even if their old one did fit many would like to just have a clean new filter instead of recharging there old one(if that is an option) or going out to find a new one to fit the new pipe. Also if there want to sel their old intake it having a filter certainly makes it more likely to be quickly sold as it's a whole unit. i think you should offer an optional filter with the kit, i'd offer both a a K&N and a cheapo alternative. mark em both up 10 bucks for the fact i don't have to drive to buy one and you'd have a sale...then again my apexi is just fine . then again intakes are 95% sound, 5% performance...
Old Aug 4, 2008 | 08:40 AM
Forgive me for mistyping the diameter. The 3" diameter one is the model we make for the Ford Focus. We would make the stock diameter for the maxima MAF tube and optionally make a larger one for people interested in them (tuning required for larger maf tubes to achieve optimal performance).
We can make the 3" TBs if there is interest as well.
Old Aug 4, 2008 | 09:14 AM
Torgus's Avatar
place racing went out of buisness.
i'd make one like that if i were you, as it's agreed upon here that it's the best by everyone as far as aftermarket goes for our cars.
can't find a pic i'm sure someone will post up a pic
anywho good luck!
Old Aug 4, 2008 | 11:36 AM
Gemner's Avatar
the 3" MAF fad has kind of died out here. reviews ranged from several HP and added throttle response to lost hp altogether
Old Aug 4, 2008 | 12:37 PM
Well, it isn't really a FAD, the reasoning behind it is that it will change the range of metering ability of the sensor since you are increasing the cross sectional area of the tube. This will aid in tuning when you have a Forced Induction or high compression Naturally Aspirated setup. If the OEM 2.75" diameter is sufficient for meterability, then it isn't necessary to increase the tubing diameter. Hence why I said it would be an option since we can make anything you want, realizing that there is reasons to increase the tubing size for meterability if necessary.
Cheers,
Brian
Old Aug 4, 2008 | 01:53 PM
Gemner's Avatar
you didnt understand what i meant. last year it was a really popular thing to be doing on this board (bigger ID MAF tube), but now not so much
Old Aug 4, 2008 | 02:49 PM
Torgus's Avatar
oh you're in boston!
you can use me for a guinnie pig!
i wantz a place racing style intake!
Old Aug 4, 2008 | 02:55 PM
I thought you meant FAD in general (globally). Basically we can do either. Larger doesn't necessarily mean better.
oh you're in boston! you can use me for a guinnie pig!
Does anyone have pictures of this Place Racing intake?
This started as just making the MAF adapter flanges or MAF Tubes, but the tubing, couplers, clamps, and filters aren't difficult to pull together if a group wants this type of setup.
Old Aug 4, 2008 | 03:12 PM
Gemner's Avatar
yeah i assumed thats where the miscommunication was. a bigger ID MAF tube is good for a lot of people (i have one) and by no means should be ruled out. they have been proven (here) to make power under the right conditions
Old Aug 5, 2008 | 04:48 AM
nismomaxct's Avatar
I just noticed you were in Boston. If you need someone to test out the replacement tube and TB (if you decide to do it) I would love to help out.
Old Aug 5, 2008 | 07:03 AM
Torgus's Avatar
nismomaxct to slow.
i'll find a pic of it for you right now...
http://www.geocities.com/nismorg/Maxima/cai.html <--- how to install it. not the best write up but the 1st one i found...
what used to come in the kit:
1 maf adapter
2 pipes
1 filter
3 silicone couplers
6 banjo clamps
1 instructions for one swedish made ***** enlarger
fully installed:
there you go.
Gemner: can you link me to the thread about the 3'' actually helping. cuz i'd be interested in doing it myself. also what are the right conditions? all na bolt ons + tune?
Old Aug 5, 2008 | 07:17 AM
hi-tek22's Avatar
looks very clean...i like
Old Aug 5, 2008 | 12:50 PM
nismomaxct's Avatar
nismomaxct to slow.
I know, but I figured that I could test it on a boosted car and you could test it out on your NA car.
Old Aug 5, 2008 | 01:28 PM
mist max2000's Avatar
if you made an intake identical to the design of the PR one i wuold be in for it, most likly along with alot of other members assuming pricing was right...
Old Aug 5, 2008 | 08:08 PM
Great comments so far, keep them coming. Just noticed that there seems to be a large 5th gen contingent from Mass... where are the other states?
Old Aug 5, 2008 | 08:16 PM
VTMaxima's Avatar
could you do anything for the 4th gens?
Old Aug 5, 2008 | 08:22 PM
Yes we can. I figured there was a lot out there already.
The mission of our company is to develop and produce high quality and high performance parts. We like to produce parts that do not overlap with other companies because we work with cars that often do not have a lot of aftermarket support, so doubling up effort on one part is inefficient use of time and resources.
If there is a need you are interested in us looking into please PM me.
Thanks,
Brian
Old Aug 5, 2008 | 08:31 PM
VTMaxima's Avatar
I just pmed you.
Old Aug 5, 2008 | 09:29 PM
VTMaxima's Avatar
Thanks for the quick replay cant wait to see the finished product.
Old Aug 6, 2008 | 06:59 AM
NmexMAX's Avatar
dot dot dot ...
But Cattman is still in business & eBay is always there.
Old Aug 6, 2008 | 07:37 AM
Torgus's Avatar
i thought cattman was perm out of stock? seeing as PR was making them for him...
and ebay is empty...
Old Aug 6, 2008 | 08:21 AM
Thanks,
Brian
then you've come to the right place lol (im in CT BTW)
Old Aug 6, 2008 | 08:32 AM
NmexMAX's Avatar
dot dot dot ...
The reason for the larger MAF housing is not peak values, but far better throttle response and low end torque increase.
Old Aug 6, 2008 | 08:38 AM
mtrai760's Avatar
'Trynna' is not a word
I just got one from him, oh, 8 months or so ago. It was not the same thing that PR supplied with there CAI's.
Old Aug 6, 2008 | 08:39 AM
Zack342's Avatar
Brian I also have a throttle body you can use.
Old Aug 6, 2008 | 08:44 AM
NmexMAX's Avatar
dot dot dot ...
The knock off eBay units do the same thing, so I didn't mean look for PR CAI on eBay.
There are many knock offs that do the same thing.
As far as the MAF adapter thing goes, this would have been nice about a year or 2 ago when I was trying to get Berk to custom make me a larger unit. He kept me hanging until finally one day, he told me he couldn't do it. So I had one made
Old Aug 6, 2008 | 09:00 AM
nismology's Avatar
A larger MAF tube with the flange welded on would be sweet.
Old Aug 6, 2008 | 09:02 AM
NmexMAX's Avatar
dot dot dot ...
Extremely. x2
Old Aug 10, 2008 | 07:43 PM
Other interest in these? Or comments about the intake side of things?
Old Aug 10, 2008 | 08:58 PM
DrunkieTheBear's Avatar
Turbo'd Saab
I would be interested. I should pull my LR maf housing now and sell it before its too late
Old Aug 10, 2008 | 09:22 PM
nismology's Avatar
I'm guessing there's no plan to weld the MAF adapter flange on...? I know I'd probably be in the minority but this is a feature I will need for my setup.
Old Aug 10, 2008 | 09:42 PM
2002AltimateV6's Avatar
You've gotten an Altima interested in this. I'd like one with the MAF adapter welded on though so it can just bolt onto my current intake.
Old Aug 12, 2008 | 02:43 PM
PulsarGTS's Avatar
I'd be down for a 3"ID MAF tube. Saves money over having to do everything seperately. You should really post this in the 5/5.5th gen forum, I just happened to wander into the general forum and see this.
Old Aug 15, 2008 | 05:40 PM
Might be a good idea!
Welding the flange on is not likely, but a billet replacement piece to replace the MAF adapter would, much better build quality. Or the option of the MAF Tube (replaces stock sensor housing).
As above, likely not welded, but a billet aluminum piece (1-piece machined)
Great, might post another thread unless a moderator can move this one.
