Weird engine start when warm?
Old Aug 7, 2008 | 09:13 AM
n3985's Avatar
大陆弟弟
On cold starts, my car starts on first crank. On warm starts, it'll start after a couple cranks but feels like it is "stalling" right before it actually starts. The cranking "sound" is not as apparent when warm, and always hear knocking sounds as if the IM is banging into the FSTB (does not happen on cold starts).
Could my starter be binding when warm? Car drives fine afterward, no CEL or anything. Battery is Optima Red, changed couple months ago.
Old Aug 7, 2008 | 02:50 PM
jasonmax's Avatar
mine sometimes sounds flooded; it shakes more starting when warm.
Old Aug 7, 2008 | 07:15 PM
Torgus's Avatar
#1 look to see if it's actually hitting the fstb which it shouldn't under any conditions unless you installed in wrong...which is hard to do.
one thing worth trying is but your key into the 'on' position for a few seconds before you crank it and see if it still happens...
good luck!
Old Aug 7, 2008 | 07:18 PM
n3985's Avatar
大陆弟弟
Always left key in "on" for few seconds, and the FSTB *might* be hitting is due to IM spacers. But still can't figure out the almost stalling when warm issue, idle and everything is perfect after, just the start portion -_-
Old Jun 24, 2009 | 12:58 PM
cmd26's Avatar
i have this problem now also pump the brakes before u start it build up the pressure n it will start right away i dont y this works but it does
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
305head
Aug 26, 2015 09:03 PM
Jcof88
Aug 3, 2015 10:43 PM
