Running real lean please help
Old Aug 23, 2008 | 01:40 PM
johnnyd2k2's Avatar
So I just had the max dynoed at NE Dyno and I seem to have some issues. It's running lean and I'm not sure why. Last weekend I had a SSIM done which may have caused it but I'm not sure cuz I never dynoed before so what could be causing this and is that why my numbers were lower than expected? I only have a few mods including the SSIM an Injen Intake and Megan Racing catback but I was expecting more than 203-211whp. Here is the graph where do I go from here?
Old Aug 23, 2008 | 02:09 PM
NmexMAX's Avatar
dot dot dot ...
Do you have a test pipe or a cat? If you have the stock cat and used a tailsniffer, that is the cause of it.
Here's a comparison of mine when I had a cat and when I removed it.
Old Aug 23, 2008 | 02:22 PM
johnnyd2k2's Avatar
So its possible that the readings are off but why so are my # so low I thought 203-205 was stock whp I know I don't have a lot of mods but does this seem right?
Old Aug 23, 2008 | 02:26 PM
NmexMAX's Avatar
dot dot dot ...
Seems right.
What tranny do you have? Looks like an auto. What gear did you dyno in & do you have the runfiles?
Old Aug 23, 2008 | 02:30 PM
johnnyd2k2's Avatar
It is an auto I did 3 in drive and the other 2 in 2nd and 3rd I've got all the run files.
Old Aug 23, 2008 | 02:36 PM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/dyno-discus...no-thread.html
Old Aug 23, 2008 | 09:31 PM
PulsarGTS's Avatar
205-210whp is stock for a maual, auto are usually around 190whp so your not looking too bad really.
MAXSE5SPD
Sep 17, 2022 04:00 AM
The Frye
Sep 2, 2021 11:03 AM
Mar 12, 2020 12:06 AM
JoshG
51
Sep 21, 2015 10:41 PM
