tps on a 03 max
Old Sep 7, 2008 | 11:50 AM
maxs4life's Avatar
tps on a 03 max
I have a 03 max and my ses light... i think it is my tps sensor.... i need the location of this sensor and how do i remove it...
Old Sep 7, 2008 | 03:49 PM
Scottwax's Avatar
That's Mr. Detail to you
http://forums.maxima.org/5th-generat...nsor-help.html
http://forums.maxima.org/5th-generat...where-ecu.html
Those ought to give you some help, not sure how much though.
Old Sep 7, 2008 | 04:22 PM
P. Samson's Avatar
You "think" it's the sensor.......you better make damn sure......what codes have you? P0222 and P0223 are the associated fault codes. Unless you've gone into fail safe, then I doubt that this is your problem. The sensor is incorporated into the throttle actuator and if it's actually the "TPS", you're looking at a throttle actuator replacement. Checked for loose connectors, bare wires, corroded grounds etc.? Have you disconnected/reconnected the connector on the TB?
Old Sep 8, 2008 | 12:54 AM
pmohr's Avatar
No more Maximas...
Not just the throttle motor and electronics assembly itself (as you can't buy those from Nissan) but a whole new throttle chamber. Pricey from Nissan, cheap(er) from a junkyard.
OP could also have a faulty APPS or two, but who knows until he gets back with the code...
OP: PM me if you need a throttle chamber, I can help with that.
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
maxima297
Sep 30, 2015 03:32 PM
