hole in firewall for wiring.
Old Sep 9, 2008 | 04:11 PM
mymaxi41691's Avatar
Anyone know where i can pull wires from the engine bay to run to where my pedals are?
Old Sep 9, 2008 | 04:32 PM
maxspeedse02's Avatar
Thinks he is fast
If your car is an automatic then you can run the wiring through the grommet where the clutch master cylinder would have been. Otherwise there is a spot where other wiring is routed that I used on the driver's side that runs near the door hinge. If you search you can find pictures, try the audio forum or take a flashlight and look. Its really not too hard to find.
Old Sep 9, 2008 | 04:40 PM
Puppetmaster's Avatar
You can use the opening where the hood release cable runs, it is inside the driver side fender well. That's how the power wiring for my Basslink is routed.
Actually, that might be the same opening he's ^^ talking about.
Old Sep 9, 2008 | 04:43 PM
sublime258's Avatar
Jack up your car, take off the front drivers side wheel. Take off the plastic wheel well cover thing and you will find what they are talking about behind that. If you are facing the wheel well, it will be at around 3 o' clock in position. That's where I ran my amp wires in my 5.5 gen.
Old Sep 9, 2008 | 06:55 PM
great info guys, thanks
Old Sep 9, 2008 | 10:03 PM
kcxd35's Avatar
You don't need to take off the wheel just turn it all the way to the left and undue the screws for the fender liner...
fastcarny
Oct 12, 2015 07:06 AM
uttadms31
Sep 30, 2015 05:24 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
max ride 41
Sep 17, 2015 06:17 PM
