High beam, low beam
Old Sep 11, 2008 | 09:43 AM
feito's Avatar
High beam, low beam
ok guys, do your magic, how can I switch my lights to normal? High beams are the low beams and the low beams are the high beams, I don't know what hapeen here...thanks for all you help
Old Sep 11, 2008 | 10:19 AM
hi-tek22's Avatar
man what year maxima do you have, an 01 or 02?
did you do a 01 to 02 headlight swap?
provide more information
when did the problem start? what did you do prior to your issue?
Old Sep 11, 2008 | 10:47 AM
lowincash's Avatar
No More Maxipad
yeah mor info please. i don't understand what you're asking. is your car not normal right now? lights aren't working? please elaborate...
Old Sep 11, 2008 | 12:37 PM
feito's Avatar
sorry guys, 2000 Maxima, it happen after I changed the light bulbs so when I turn my lights on, its the opposite of what it should be, high beams are now my lows and the low beams are my high beams, could it be the relay?
Old Sep 11, 2008 | 12:59 PM
Feldman's Avatar
what kind of bulbs did you buy? sounds like leads for high and low are switched. there is only one way to plug them in so it must be the bulb...
Old Sep 11, 2008 | 01:15 PM
feito's Avatar
I got the Hella light bulbs.
Old Sep 11, 2008 | 01:35 PM
hi-tek22's Avatar
youve got regular H4 bulbs.....its damn near impossible to push the plugs in the "wrong" way...which MAY show some sign of this.....
this is strange though
Old Sep 11, 2008 | 01:52 PM
DrunkieTheBear's Avatar
Turbo'd Saab
sounds like you bought 9006 and not H4 bulbs
Old Sep 11, 2008 | 02:00 PM
808MAX-SPEC's Avatar
Does 9006 have the same 3 pin config.? and is it a dual filament?
I think those Hellas were made the wrong way. One way to find out is to put back the original bulb(s) if they haven't burned out and see if the lows and highs are still reversed. Or buy another brand.
Old Sep 11, 2008 | 02:05 PM
feito's Avatar
Thank you fellas
Old Sep 11, 2008 | 07:52 PM
flatcat19's Avatar
Wrong bulb purchased. My .02
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
maxinout93
Oct 31, 2015 02:04 AM
