button under clutch pedal
Old Sep 9, 2008 | 04:09 PM
mymaxi41691's Avatar
I was messing around and i found out that if you press the button with your finger and crank the engine, it starts! many of you most likely knew that. but i find it odd. is there anyway to keep it pushed down? or wire it so i don't have to push the clutch to start?
Old Sep 9, 2008 | 05:04 PM
sc0tty8's Avatar
Yes, you can bypass it.
Would I? No....
I have driven a few car with the switch broken/bypassed. I don't like the idea if someone else was going to drive the car...
Old Sep 9, 2008 | 05:45 PM
maxboy325's Avatar
Yes you can bypass it but you will be asking for TROUBLE
Old Sep 9, 2008 | 05:59 PM
PhalC1's Avatar
That's the button you have to bypass so you can put a remote starter on a manual.
Its dangerous if you leave it in gear though. Thats all I'll say lol
Old Sep 9, 2008 | 06:58 PM
i understand all the risks of starting it while in gear. And the main reason i want to do this is so i can install my remote start. I never leave the car in gear. And what i was thinking about doing ( if possible) is run a switch to the left side of the steering wheel, and have a toggle switch kind of. id have to flick it to start it. or keep it "flicked" when i plan on using the remote start the next morning or something. Does what im saying make sense or not really?
Thanks guys
Old Sep 9, 2008 | 07:04 PM
sc0tty8's Avatar
Thanks guys
Pin switch on e-brake handle?
I remember back in the day, there was a proximity sensor that you could put around the shifter to sense if it was in gear or not..not sure as that was hear-say...
Old Sep 9, 2008 | 07:13 PM
i was thinking one of these switches
http://cgi.ebay.com/MINI-TOGGLE-DPDT-ON-OFF-ON-SWITCH_W0QQitemZ380061082365QQcmdZViewItem?hash=it em380061082365&_trkparms=72%3A1163|39%3A1|66%3A2|6 5%3A12|240%3A1318&_trksid=p3286.c0.m14
and i was planning on leaving it switched off so it wont start without me flicking it to the on position. But when i know i need to remote start it the next morning before school, i would flick it so its on so i can use my remote start.
and it would be mounted in the spot for spare switches on the left side of the steering wheel. anyone know what im talking about??
Old Sep 9, 2008 | 09:11 PM
maxima.713's Avatar
I did that with my clutch too! I've never had any problems with it. One of my friends say its easyer to steal and I was like wtf! Is the difference?
Old Sep 10, 2008 | 04:38 PM
haha ya. cause pushing the clutch is a great theft dettarant system.
but can you explain how you rewired/relocated it? cause i looked behind the button and it has a special connector going to it.
Old Sep 11, 2008 | 03:14 PM
burnurass's Avatar
JUST SO YOU KNOW...most nissans have a neutral safety switch that you can tap into for your remote start. It is the SAFEST and should be the ONLY way to do remote start on a stick shift car. I have it on mine and it works like a charm. PearlMax96 did the install for me and he has been able to successfully find most NSS wires in most nissans.
AGAIN...Don't bypass the clutch switch!
Old Sep 11, 2008 | 07:31 PM
Zack342's Avatar
So essentially you can only remote start it if it is in neutral
Old Sep 11, 2008 | 08:06 PM
AceofSpds's Avatar
wat
Dunno if the switches in the maximas are momentary on or offs, but in my 240 i just unplugged it and i can start it w/ out depressing the clutch.
tarun900
19
Dec 20, 2021 06:57 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
