Sunroof sagging from one end
Old Sep 18, 2008 | 12:34 PM
takkar's Avatar
Hello all,
I was cleaning the car yesterday and noticed that the sunroof is sagging from one side. It's not huge, but enough to see that the glass is not flush with the top of the roof.
Any ideas what I can do to "lift" that one side up slightly. So far I haven't seen any leaks...
TIA
Old Sep 18, 2008 | 01:55 PM
kukx30de's Avatar
sure you can:
check out this website managed by our own Housecor!
http://www.innerbean.com/housecor/su...noise_fix.html
Old Sep 19, 2008 | 05:21 AM
takkar's Avatar
Thanks kukx30de ... I'll be sure to get this done asap.
Thanks again
Old Sep 19, 2008 | 06:18 AM
hi-tek22's Avatar
yea i had to do the innerbeam how to myself
I had to put about 4 clips all together in to make it sit 100% flush
two on the drivers side and two on the passenger side
Old Sep 19, 2008 | 03:09 PM
OK.Eric's Avatar
The thing with my sunroof is that it looks like the glass is flush with the roof, but the rubber seal around the glass seems to be sticking up somewhat at the front. Any ideas how to fix that? If I remove the shims it would probably make the glass lower than the roof.
Old Sep 19, 2008 | 04:16 PM
AEMAXIMA01's Avatar
The rubber around the edge of the sunroof doesn't keep water from getting in your car, so technically it shouldn't matter how 'flush' it is. There are drain hoses that keep water from getting inside your car. I had a clog in one of my drain hoses and water started leaking down the A pillar roof liner. Shot some compressed air down the drain hoses, and voila! Water drains perfectly.
bigdogsteve
Jan 31, 2018 04:18 PM
Forge277
Jun 13, 2016 09:26 PM
jonreidhead
Jan 6, 2016 09:38 AM
BobTX10
Oct 7, 2015 08:43 AM
