Two questions...odd noise and odd AC behavior
Old Sep 20, 2008 | 07:01 AM
Thorzdad's Avatar
2001 SE with 280k.
Issue 1...Odd squeak/metallic noise that is in concert with speed of wheel rotation. Starts as a squeak, similar to a caliper dragging. Gets a bit more metallic. Comes and goes. All rotors, calipers and pads check-out fine. Note, this sounds nothing like the drumming/howling associated with bad bearings.
Issue 2...The AC is engaged when you start the car. Drive the car with the AC off. Park it. Come back and start the car...the AC is on. Turn off AC. Drive. Park. Start car again...AC is on.
Any clues to either of these will be much appreciated.
Thanks,
Jim
Old Sep 25, 2008 | 07:53 AM
Thorzdad's Avatar
Update...
Fixed the AC problem. Turns out the problem was a 10-amp fuse in the passenger compartment fuse panel. I decided to look in there when the clock pod went dark a couple days after the AC weirdness started. It was the 10-amp fuse that sits at the bottom of the fuse panel. It's marked "misc. electrical" or something like that.
No fix for the noise, though. It's gone for now. I actually hate that. Makes it harder to diagnose.
Old Sep 25, 2008 | 08:04 AM
jasonmax's Avatar
Originally Posted by Thorzdad
Update...
do you have rusty rear brake pads? my rears were very rusty, and they made noise. after replacing the pads, noise gone.
Old Sep 27, 2008 | 06:27 PM
Thorzdad's Avatar
No. All brakes check out fine.
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
