What is this part?
Old Sep 30, 2008 | 01:19 PM
wyche89's Avatar
What is this part?
So, when I was installing my intake spacers, my buddy recommended that I take this part off since the hoses wouldn't connect anywhere. So I removed it and drove around without it for a while. Then I saw how it was installed on someone else's and put it back on at the NWP meet. The intake was alot louder with this part removed. It didn't seem to affect driveability of the car when it was removed, though. What is it and what does it too? Can I just take it off again without causing long term damage? I liked how the intake sounded without it.
Old Sep 30, 2008 | 01:30 PM
AceofSpds's Avatar
wat
I think its a carbon canister/vac canister. It doesn't matter if you use it or not. Just tee those vac lines together.
Old Sep 30, 2008 | 02:53 PM
2002 Maxima SE's Avatar
It's the vacuum cannister for the VAIS. With it removed, your VAIS will stay open by default. It closes (by vacuum sensor to the left) at around 2500rpm.
Old Sep 30, 2008 | 04:23 PM
hi-tek22's Avatar
so does it cause any long term detriment? (to your knowledge)
Old Sep 30, 2008 | 04:38 PM
wyche89's Avatar
now, i have the NWP block plate on there in place of the VIAS... so is this canister doing anything now?
Old Sep 30, 2008 | 04:45 PM
mist max2000's Avatar
but if you have the butterfly removed with the vias block plate then it serves no point..correct.. im interested in this.. does the car drive different with it..or are you hearing those vacume lines making noise?
:edit: you beat me lol
Old Sep 30, 2008 | 04:56 PM
asianstyle's Avatar
so with it unpluged the VIAS will stay open meaning more power all through the band instead of above a certain RPM right? if that's the case then I will unplug mine so i can have that power all the time.
Old Sep 30, 2008 | 05:12 PM
SoonerFan's Avatar
Cletus
you will have more at the top end but less at low end
the VIAS was designed the way it is for a reason....
Old Sep 30, 2008 | 05:14 PM
maxboy325's Avatar
My guess would be that you would loose a little down low but not gain alot up top with the vias still in there.... I think thats why people remove it because so much to be gained up top with more space there but you loose a little in the lower rpms.
Old Sep 30, 2008 | 05:23 PM
wyche89's Avatar
i'll experiment with it and find out
Old Sep 30, 2008 | 05:26 PM
I believe you'll lose some power on the low end.
Some folks remove it and block it off.
Old Sep 30, 2008 | 09:17 PM
CMax03's Avatar
I believe the canister works as a accumulator the allow the VIAS to open/close smoother. Not just slam open
Old Jan 3, 2009 | 06:27 PM
MIK3's Avatar
Sorry for resurecting an semi-old thread, but I ran across this. Was wondering if I'll get a CEL from removing the canister and sensor?
Old Jan 3, 2009 | 07:34 PM
MIK3's Avatar
Nevermind, it doesn't
Old Jan 4, 2009 | 09:26 PM
wyche89's Avatar
glad to have been of service
Old Jan 4, 2009 | 09:52 PM
nismology's Avatar
To answer the original question, removing that vacuum canister will hurt low-midrange torque and you will gain absolutely nothing at higher revs.
Old Jan 4, 2009 | 10:16 PM
MIK3's Avatar
...assuming the VIAS isn't completely exchanged for a NWP block plate.
Old Jan 4, 2009 | 10:42 PM
nismology's Avatar
Didn't even realize he had installed one. My bad.
Old Jan 5, 2009 | 03:42 PM
wyche89's Avatar
i have that canister on there now, along with the block plate.. so the consensus is that the canister isnt doing anything then?
Old Jan 5, 2009 | 04:08 PM
MIK3's Avatar
This is correct. The canister is used in conjunction with the VIAS butterfly valve. No valve = no need for vacuum. You can remove that and the sensor if you want to clean up your upper IM area.
Old Jan 5, 2009 | 05:39 PM
wyche89's Avatar
ok.. thanx... its not bothering anything, and im lazy, so i'll probably just leave it there
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
SpeedCrazie
Sep 16, 2016 03:41 PM
Lowered_a33
Sep 10, 2015 09:41 PM
videomano
Sep 8, 2015 03:28 PM
